Ilogic check iProperty of opened file
Hi!
Trying to check/Change iProperty of a file that has been opened by iLogic,
But the only value I get is the value from the file when the rule was launched.
I guess there is some secret-refering-stuff I dont understand 🙂
SyntaxEditor Code Snippet
FileToCheck = "C:\Vault\1782-906-R00.idw"
ThisDoc.Launch(FileToCheck)
RevOfFile = iProperties.Value("Project", "Revision Number")
MessageBox.Show(RevOfFile, "Title")
ThisApplication.ActiveDocument.Close(True)
MechMachineMan
@Anonymous wrote:
Hi!
Try:
oDoc = ThisDoc.Launch
oProp = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
MsgBox(oProp)
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Super!
I believe I kind of getting it now:)
Got it to work with:
    ' Get the active document.
    Dim oDoc As Document
   oDoc = ThisApplication.ActiveDocument
'oDoc = ThisDoc.Document'(FileToCheck)
'iLogicVb.RunExternalRule("Test show partnumber")
MsgBox(oProp)
