iLogic - Change file name in assembly
i want to ask you for help.
I have iLogic assembly of conveyor and i need rule for change all names in assembly, change part number
For better explain I attach picture.
And if possible it save with new names.
Thank you so much
Marek
bradeneuropeArthur
You could use the Design-Assistant from Autodesk for this!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Design-Assistant we don´t have in company..
bradeneuropeArthur
it is shipped with inventor!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
And what about my rules ? Will be function when I change names files with Design Assistant ? 🙂
I need function rules with new name files. Because contracts need still a lot of changes.
