iLogic Drawing Automation
Cosmin_V
Cosmin_V
Hi
I have a iLogic Assembly and I do a "User Parameter" (Do_ Drawing ="No", "Yes" ).
I would like if is possible when I chose "Yes" to open the assembly in the Drawing template.
Is that Possible?
Cosmin_V
I have found some thinks to do it bu is stil not complete, I can't control the scale completely yet, just the first number.
And I still need to control the: sheet format, borders, title block, and sketch symbol.
Can someone help me whit this?
I have see in some tutorials then is possible when the drawing is create, the sheet is all ready have a form on...How they do that?
Many Thanks!....
Cosmin_V
Sorry I post before I add my rule
If Drawing="Yes" Then
Dim  oDoc As Document
oDoc = ThisDoc.Document
'Create a drawing from the drawing template
Dim templateFile As String
templateFile = "C:\WF\CAD\Inventor 2016\Templates\CUN\CUN.idw"  '''Place the path of your template idw
Dim oDrawingDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,templateFile,True)
oDrawingDoc.Activate()
Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
Dim oPoint1 As Point2d
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(50, 50)
Dim oView As DrawingView
oView = oSheet.DrawingViews.AddBaseView(oDoc,oPoint1, 1, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
'oView = oSheet.DrawingViews.AddBaseView(oDoc,oPoint1, 1, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
oDoc.ReleaseReference
