Ilogic; BOM Qty; need help with code
I modified a code for BOM qty across all parts. The previous code only works with "Parts only"...
The modified code works on the Structured BOM.
That said it does not go through all sub assemblies "levels".
Can some one help me so it runs on all levels?
Josh
Inventor 2017
SyntaxEditor Code Snippet
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
oBOM.StructuredViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMView.BOMRows
    'Set a reference to the primary ComponentDefinition of the row
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRow.ComponentDefinitions.Item(1)
    Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
    Dim CompFileNameOnly As String
    Dim index As Integer = CompFullDocumentName.lastindexof("\")
    CompFileNameOnly = CompFullDocumentName.substring(index+1)
    'MessageBox.Show(CompFileNameOnly)
    Dim Qty As String
    Qty = oBOMRow.TotalQuantity
    iProperties.Value(CompFileNameOnly, "Custom", "PartQty") = Qty
    iProperties.Value(CompFileNameOnly, "Custom", "SO") =iProperties.Value("Custom", "SO")
Next
MechMachineMan
You need to use recursion.
Samples of recursion found here:
http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Sub Main()
doc = ThisDoc.Document Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition Dim oBOM As BOM = oAssyDef.BOM oBOM.StructuredViewEnabled = True Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured") Dim oBOMRow As BOMRow Dim oCompDef As ComponentDefinition
Call SetRowProps(oCompDef As ComponentDefinition, QTY As String)
If Not oBOMRow.ChildRows is Nothing
Call RecurseBOMRow(oBOMRow)
End if
Next
End Sub
Sub RecurseBOMRow(oBOMRow As BOMRow)
For Each oBOMRow In oBOMRow.ChildRows
Call SetRowProps(oCompDef, oBOMRow.TotalQuantity)
End ig
Next
End Sub
Sub SetRowProps(oCompDef As ComponentDefinition, QTY As String)
iProperties.Value(CompFileNameOnly, "Custom", "PartQty") = QTY
iProperties.Value(CompFileNameOnly, "Custom", "SO") = iProperties.Value("Custom", "SO")
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for the additional info! I will read this thoroughly  today.
I tired your code. I am getting errors in line 19
 Call SetRowProps(oCompDef As ComponentDefinition. QTY As String)
any thoughts?
MechMachineMan
If you are digging this far into code/iLogic, it would really benefit you to read some more about programming and basic debugging.
You would quickly find that the only place an "As" should occur is when declaring a variable or function, and not in a function call.
This is like 101 level programming bugs.
Sub Main()
       'OLD : NOTICE THE 'AS' KEYWORD INCORRECTLY THERE.
      'Call SetRowProps(oCompDef As ComponentDefinition, QTY As String)
'New Line. Notice the LACK of 'As' Keyword. Call SetRowProps(oCompDef, oBOMRow.TotalQuantity) If Not oBOMRow.ChildRows is Nothing Call RecurseBOMRow(oBOMRow) End if Next End Sub Sub RecurseBOMRow(oBOMRow As BOMRow) For Each oBOMRow In oBOMRow.ChildRows Dim oCompDef As ComponentDefinition oCompDef = oBOMRow.ComponentDefinitions.Item(1) Call SetRowProps(oCompDef, oBOMRow.TotalQuantity) If Not oBOMRow.ChildRows is Nothing Call RecurseBOMRow(oBOMRow) End ig Next End Sub Sub SetRowProps(oCompDef As ComponentDefinition, QTY As String) Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName Dim CompFileNameOnly As String Dim index As Integer = CompFullDocumentName.lastindexof("\") CompFileNameOnly = CompFullDocumentName.substring(index+1) 'MessageBox.Show(CompFileNameOnly) iProperties.Value(CompFileNameOnly, "Custom", "PartQty") = QTY iProperties.Value(CompFileNameOnly, "Custom", "SO") = iProperties.Value("Custom", "SO") End Sub
Justin K
