set units from US to ISO
LARA-Engineering
LARA-Engineering
after installing and already working with 2018, I discovered all my physical material units are set to US (psi, lb, F, etc.)
This should be ISO (MPa, N, kg, C etc.)
How is this possible and how can I change to ISO ?
The document setting are ISO !!
Freddy de Jong
LARA Engineering
Rob67ert
In the Material browser, the lower left icon, Set Display Units.
Safe it to your default template file.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
LARA-Engineering
thanks a lot,
so many set-up options, you dont see the most simplest anymore  Smiley Frustrated
Freddy de Jong
LARA Engineering
Rob67ert
No problem.
First I thought the all the setting would be in one or 2 places; Document and Application setting.
But you still have some settings in your .ipj, your iLogic Configuration, the units in your material...and I guess I forgot a few.
Robert
