If no interference then Delete - Revit export - simplification
andrew_canfield
Message 1 of 8
andrew_canfield
Take an assembly made up of 100mm^3 cubes - packed together occupying 5m^3 (the size of your model to export)
Place your model inside the cubes.
Run the code which tests each cube for interference - if yes, keep the cube, no, delete the cube.
The result is a 'Minecraft' version of the model - this can be derived to remove seams between faces, then exported to Revit.
(Shrinkwrapping current models is producing too large a file, a simplifying by hand would be time consuming).
I wish I could code this!
Replies (7)
Message 2 of 8
LukeDavenport
Hi Andrew,
While I'm intrigued by the idea - and it would definitely be a fun coding project - if you had the cube size small enough to give a decent geometric representation of the shape, you'd probably have quite a lot of cube faces, making a large file size, which might end up defeating the object of the exercise. I wonder if a balance between cube size and file size would be possible?
Love the idea though! Tempted just to do it for fun.
Luke
Message 3 of 8
andrew_canfield
I guess tweaking the cube size could be an option, program creep already!
I've found this:
https://forums.autodesk.com/t5/inventor-customization/ilogic-and-analyze-interference/td-p/3414039
Which half way there..i think!
Message 4 of 8
andrew_canfield
If could cycle through an assembly - turn every part red.
Run the code copied from before:
I've commented out the message box & turned all the parts yellow.
SyntaxEditor Code Snippet
Sub Main
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
' Add each occurrence in the assembly to the object collection.
Dim oCheckSet As ObjectCollection
oCheckSet= ThisApplication.TransientObjects.CreateObjectCollection
Dim oOcc As ComponentOccurrence
For Each oOcc In oAsmCompDef.Occurrences
oCheckSet.Add (oOcc)
'Component.Color(FullOccurrenceName(oCheckSet.oOcc)) = "Blue"
Next
' Call the AnalyzeInterference method, passing in a single' collection. This will cause it to compare everything against' everything else.
Dim oResults As InterferenceResults
oResults = oAsmCompDef.AnalyzeInterference(oCheckSet)
' Display the results of the interference.
MessageBox.Show(oResults.Count & " Interferences found ","iLogic")
Dim oResult As InterferenceResult
Dim iCount As Integer
iCount = 0
For Each oResult In oResults
iCount = iCount + 1
Component.Color(FullOccurrenceName(oResult.OccurrenceOne)) = "Yellow"
Component.Color(FullOccurrenceName(oResult.OccurrenceTwo)) = "Yellow"
'MessageBox.Show("     " & FullOccurrenceName(oResult.OccurrenceOne) & "      (colored yellow)" _'& vbLf & "interferes with " _'& vbLf & "     " & FullOccurrenceName(oResult.OccurrenceTwo) & "      (colored magenta)" _'& vbLf & "" _'& vbLf & "Volume: " & Round(oResult.Volume,5) & " cm^3", _'" Interference "& iCount)'Component.Color(FullOccurrenceName(oResult.OccurrenceOne)) = "As Material"'Component.Color(FullOccurrenceName(oResult.OccurrenceTwo)) = "As Material"
Next
End Sub
' Used to display the full path of an occurrence. This is the path of the' occurrence within the assembly structure.
Private Function FullOccurrenceName(Occ As ComponentOccurrence) As String
Dim i As Integer
For i = 1 To Occ.OccurrencePath.Count
If i = 1 Then
FullOccurrenceName = Occ.OccurrencePath.Item(i).Name
Else
FullOccurrenceName = FullOccurrenceName & "\" & Occ.OccurrencePath.Item(i).Name
End If
Next
End Function
Then delete all the red parts..
How do you cycle through an assembly, change a parts color & then delete a part which is red?
Message 5 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrew_canfield,
Try below iLogic to change color of parts in Assembly.
Color_Name = "Yellow"
Dim doc = ThisDoc.Document
Dim oDef As Inventor.AssemblyComponentDefinition
oDef = doc.componentdefinition
For Each occ As Inventor.ComponentOccurrence In oDef.Occurrences.AllLeafOccurrences
	Component.Color(occ.Name) = Color_Name
Next
Try below iLogic to delete part if part color is red.
Color_Name = "Red"
	If Component.Color(occ.Name) = Color_Name Then
		occ.Delete()
	End If
Next
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 6 of 8
andrew_canfield
Thankyou.
Part inserted in red blocksPart inserted in red blocksPart inserted in red blocksPart inserted in red blocksanything with interference turned yellowanything with interference turned yellowRed blocks deleted - simple substitute next :)Red blocks deleted - simple substitute next 🙂
Message 7 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrew_canfield
Looks cool!!!
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 8
andrew_canfield
A slightly more rigorous test 1000 part assembly - took a while to process but the concept works.
Below the derived part is 26MB (LHS) & simplified blocked version 1MB (RHS)
Smaller cubes would improve the resolution.
Could someone take it further, make it faster?
Regards
Andrew
