iAssembly error: while publishing factory table in the main assembly
- Mute
- Permalink
- Report
Hi Community,
Please see below the error which I faced during inserting iAssembly into the main assembly.
Application – Inserting number of variations of Handrails into the main structure.
We would prefer iAssembly over iPart as we extract the MTO of all assemblies and subassemblies.
Details of Standard Handrail-
Two types of Handrails – Double Panel and Single Panel with variations of Fixed & Removable type of each panel. In Double Panel, the handrail length remains fixed whereas in Single Panel it varies.
Procedure of creation of iAssembly-
- In the Double Panel, the design remains much simpler than the Single Panel. Hence I depict the creation of iAssembly of the single panel.
- Factory Table in which all the parameters (STIFF_LG, STIFF_HT, SGP_LG etc.) are sought from Parts associated with assembly (Linked Parameters from Part)
- To get those linked Parameters, a small iLogic code was added.
Till this level, everything remains smooth and that iAssembly runs flawlessly with all variations.
However when I start pushing this assembly in the main structural model to have different variations of the lengths, the problem starts popping up.
The lengths of panels should be 3000mm and 2200mm respectively as per the factory table however those remains identical.
All my efforts remain futile till now, hence writing this email to you to get any further assistance from your side, if possible.
