Formatted Text without style overrides
Curtis_Waguespack
Consultant Consultant
Curtis_Waguespack
I'm trying to get the text from a general note on a drawing, and insert it into a form within an add-in.
But, if the note has style overrides such as this:
(see attached 2022 drawing example)
This is the result that is returned using the GeneralNote.FormattedText
MsgBox(oGeneralNote.FormattedText,,"Formatted Text")
and this is the result using just GeneralNote.Text
MsgBox(oGeneralNote.Text,,"Text")
Neither of those are the results I'm after.
Ultimately, I'm looking to get something like this in a form:
Not this:
and not this:
Is there another way to extract the text that I'm overlooking?
JelteDeJong
You could try to replace the text parts that you don't want with empty strings. And the "<br />" with new lines. Something like this:
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
' a reference to the active sheet.
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
' a reference to the GeneralNotes object
Dim oGeneralNotes As GeneralNotes
oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes
Dim oGeneralNote = oGeneralNotes.Item(1)
Dim stext = oGeneralNote.FormattedText
stext = Text.RegularExpressions.Regex.Replace(stext, "<StyleOverride [\s\S]*?>", "")
stext = Text.RegularExpressions.Regex.Replace(stext, "</StyleOverride>", "")
stext = Text.RegularExpressions.Regex.Replace(stext, "<Br/>", System.Environment.NewLine)
MsgBox(stext,, "Formatted Text")
Jelte de Jong
Blog: hjalte.nl - github.com
Curtis_Waguespack
Thanks @JelteDeJong !
I think that will work!
Curtis_Waguespack
Hmmm, I thought that was going to provide a solution... and it did for the question I initially asked.
But upon further testing, I'm not seeing a way to extract the value from an iProperty (such as Part Number) or derived property ( such as sheet number) .
It is instead just returning the property names
( example 2022 files attached)
stext = Text.RegularExpressions.Regex.Replace(stext, "<StyleOverride [\s\S]*?>", "") stext = Text.RegularExpressions.Regex.Replace(stext, "</StyleOverride>", "") stext = Text.RegularExpressions.Regex.Replace(stext, "<DerivedProperty [\s\S]*?>", "") stext = Text.RegularExpressions.Regex.Replace(stext, "</DerivedProperty>", "") stext = Text.RegularExpressions.Regex.Replace(stext, "<Property [\s\S]*?>", "") stext = Text.RegularExpressions.Regex.Replace(stext, "</Property>", "") stext = Text.RegularExpressions.Regex.Replace(stext, "<Br/>", System.Environment.NewLine) MsgBox(stext,, "Stripped Formatted Text")
JelteDeJong
It became a bit more complex and also a bit longer. Also, it's not complete in all cases. (have a look at the comments in the code.) But It will work for your example.
Public Sub Main()
    stext = RemoveStyleOverride(stext)
    stext = AddNewLines(stext)
    stext = ReplaceDerivedProperty(oActiveSheet, stext)
    stext = ReplaceProperty(oActiveSheet, stext)
End Sub
Private Function AddNewLines(text As String)
    Return System.Text.RegularExpressions.Regex.Replace(text, "<Br/>", System.Environment.NewLine)
End Function
Private Function RemoveStyleOverride(text As String)
    Dim regexProperty = "<StyleOverride [\s\S]*?>([\s\S]*?)</StyleOverride>"
    Dim regex As New Text.RegularExpressions.Regex(regexProperty)
    Dim someThingChanged = False
    Do
        Dim match As Text.RegularExpressions.Match = regex.Match(text)
        If (match.Success) Then
            Dim orgText = match.Groups.Item(1).Value
            text = text.Replace(match.Groups.Item(0).Value, orgText)
            someThingChanged = True
    Loop While someThingChanged
    Return text
End Function
Private Function ReplaceDerivedProperty(sheet As Sheet, text As String)
    Dim regexProperty = "<DerivedProperty DerivedID='([\s\S]*?)'>([\s\S]*?)<\/DerivedProperty>"
    Do
            Dim derivedID = match.Groups.Item(1).Value
            Dim newValue = String.Empty
            ' This are not all ID's you might want to add more.
            Select Case derivedID
                Case "29703"
                    newValue = ThisDoc.Document.Sheets.Count
                Case "29707"
                    newValue = sheet.DrawingViews.Item(1).ScaleString
            End Select
            text = text.Replace(match.Groups.Item(0).Value, newValue)
    Return text
End Function
Private Function ReplaceProperty(sheet As Sheet, text As String)
    Dim regexProperty = "<Property Document='([\S]*?)' PropertySet='([\s\S]*?)' Property='([\s\S]*?)' FormatID='([\s\S]*?)' PropertyID='([\s\S]*?)'>([\s\S]*?)<\/Property>"
        Dim docDirection = match.Groups.Item(1).Value
        Dim propSetName = match.Groups.Item(2).Value
        Dim propName = match.Groups.Item(3).Value
        Dim doc As Document = ThisDoc.Document
        ' this if statement is just 1 example. At som point you might want to look for other documents
        If (docDirection.Equals("model")) Then
            doc = sheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
        Dim propSet = doc.PropertySets.Item(propSetName)
        Dim propValue = propSet.Item(propName).Value
        Return text.Replace(match.Groups.Item(0).Value, propValue)
    Return text
End Function
Jelte de Jong
Curtis_Waguespack
HI @JelteDeJong
Thanks for the taking the time on this!
I was hoping I was just overlooking some other, more simple method.
I'm not sure how far to take this... 🤔 🤔 🤔
do I really want to have a select case for every possible derived property?
can I extract the referenced view more dynamically?
I don't know?
It doesn't seem like it should be this involved, to get the text out 😉
But I appreciate the effort and time you put into looking into this!
