Detail View callout and Leader Notes Style & Layer change using iLogic
knb7264
knb7264
How to change Style and Layers for the following objects using iLogic ?
1. Detail Views Callout curve
2. Section Lines
3. Leader Notes
4. Partlist
WCrihfield
The LeaderNote object has a property called 'DimensionStyle', which is where you would set its Style, and it has a property called 'Layer', which is where you would set its Layer.  The LeaderNote object can be found under DrawingDocument.Sheets.Item(1).DrawingNotes.LeaderNotes.Item(1).
The PartsList object has a property called Style, and a property called Layer.
Section lines are usually SketchLines within a DrawingSketch, belonging to a DrawingView (DrawingView.Sketches), where the geometry has been made visible outside of the sketch, and assigned to a layer.  Then the SketchLine objects each have several properties for things like LineType , LineScale, LineWeight, OverrideColor, and so forth, but all those aspects could also be set by the Layer itself, because the SketchLine objects also have a property called Layer.  There is actually a sub-type of the DrawingView object called SectionDrawingView, and it does have a property called SectionLineSketch, which is most likely where you would obtain this specific sketch.
I am not sure what you mean by detail view call-out curve, but it sounds like that would also be geometry within a drawing sketch, which could be controlled much the same way as the section lines above.  There is a special sub-type of the DrawingView object called DetailDrawingView.  And that object does have a property called BoundaryLayer.  That may also be what you are looking for.
Wesley Crihfield
(Not an Autodesk Employee)
