I think the ilogic code is broken
EmreYucel34
EmreYucel34
Greetings, we use the canvas ERP program and an iLOGIC code has been written that automatically assigns numbers to the ERP program, automatically assigns numbers to the canvas system, but whatever change has happened, even if the previously assigned number is deleted, it cannot assign that number, even if the previously assigned number is deleted, it defines a new number instead, it defines the previously defined numbers that it has found idle recently and leaves us in a difficult situation, can you help us with this issue?
bradeneuropeArthur
We could try if you share the code.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
