I need a macro that derives parts
info5RLCG
info5RLCG
I'm new to VBA and need a little bit support.
There is one task that I would like to automate, which would safe me so much time:
Let's say I have a part Master.ipt in which there are five volumes.
I would like to derive each volume into an individual part.
In other words the macro has to derive 1.ipt, 2.ipt, 3.ipt, 4.ipt and 5.ipt from the Master.ipt.
Could anyone please give me a tip how I could achieve this?
I need this to be working for Inventor Version 2021
Thanks alot for your help!
bradeneuropeArthur
Could you share a file example with the volumes?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
info5RLCG
sure, please find attached the Master.ipt and also the 1.ipt and 2.ipt (3.ipt, 4.ipt and 5.ipt would follow the same logic) that should be derived from the master.ipt.
Thanks in advance!
bradeneuropeArthur
Isn't this what you need?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
info5RLCG
Great! This is what I need! Problem solved
