Ilogic to supress individual welds?
patrick3HNXX
patrick3HNXX
I have a weldment that has different configurations and would like to be able to suppress or at least turn off visibility for individual weld features, not the whole tree. Is this possible?
WCrihfield
Hi @patrick3HNXX.  That is a new one.  I see that we can suppress individual welds manually, but the individual weld API objects (code representation) do not have a Suppress method or a Suppressed property.  Therefore I can only guess that we would need to use the WeldmentComponentDefinition.SuppressFeatures method to suppress them.  I have never tried it before though.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
That SuppressFeature method wants us to supply an ObjectCollection into it, which specified which features to suppress.  However, I have tried adding a Weld object, and a WeldBead object into that collection, and instead of suppressing those objects, it throws an error.  I also tried supplying WeldsComponentDefinition.Occurrences.Item(1) (a ComponentOccurrence type object), but there were none, even though I have some welds in the weldment type assembly at the time, so that route is not working either.  I know that the command that gets executed when we choose the SuppressFeature option is "AssemblySuppressFeatureCtxCmd", so my next thought would be to add either a Weld object, or a WeldBead object to the Document.SelectSet, using its Select method, then execute that command.  That is not an ideal way to do it, but is the only way I can think of right now.  Maybe someone else has tried to do this before.
Wesley Crihfield
