I have i probel with my costrans after supressing with iLogic
Hello again my frends!
Yes i have made my model to work now. Thnaks for the support. My another qustion, when i have a case in my model in there all parts from a pattern supress are, i bekomme an error message.
Case 1:
Case 2:
The parts in the middel are now supress, and i bekomme this error.
Is there a way to permanently delete the sick constrans in "case Lamellen_Anzahl = 2" and then in case >=3 they muss be back!
Thank you
Aleksandar Jovicic
MechMachineMan
Oh my. You really need to polish up on those google skills, Aleksander.
http://lmgtfy.com/?q=autodesk+inventor+%2B+suppress+sick+constraints
Look at about the 5th website down. Should be a whole BLOG about this issue.  ("From the Trenches" As blogged by Curtis Waguespack)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
CCarreiras
Hi!
Sometimes it happens...
When you suppress the parts... also suppress the constraints
You can do it in the same rule you suppress the parts.
CCarreiras
