i have a error 16 and i can't fix it
341472
341472
Community Visitor
Community Visitor
I first couldn't download Inventor. To fix that, I deleted all the Autodesk files (or at least I thought I did that), becaus I think I left some files behind. After that, AutoCAD stopped working and gave me an error (I’m not sure which one). I managed to fix that, but now Inventor isn't working and shows Error 16. I tried a clean install, but it didn’t help.
bradeneuropeArthur
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Failed-to-initiali...
https://resources.imaginit.com/support-blog/inventor-2024-failed-to-initialize-a-component-for-acces...
did you try these?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
