How to select all the same (same files) parts in assembly
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
How can I quick select all same parts within an assembly.
Dim s As Inventor.ComponentOccurrence = ThisApplication.CommandManager.Pick(Inventor.selectionfilterenum.kAssemblyLeafOccurrenceFilter,"select")
	'MsgBox(s.Name)
	Dim f As Array = Split(s.Name, ":")
	'MsgBox (f(0))
	Dim a As Inventor.AssemblyDocument = ThisDoc.Document
	Dim d As Inventor.SelectSet = a.SelectSet
	For Each c As Inventor.ComponentOccurrence In a.ComponentDefinition.Occurrences.AllLeafOccurrences
		If c.Name.Contains (f(0)) Then
			d.Select(c)
			End If
		Next
End Sub
The above works to slow.
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Ralf_Krieg
Hello
Maybe this is a faster way.
Dim s As Inventor.ComponentOccurrence = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kAssemblyLeafOccurrenceFilter,"select")
Dim oOccEnum As ComponentOccurrencesEnumerator = a.ComponentDefinition.Occurrences.AllReferencedOccurrences(s.Definition)
Dim oObjColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oOcc As ComponentOccurrence In oOccEnum
	oObjColl.Add(oOcc)
Next
d.SelectMultiple(oObjColl)
R. Krieg
RKW Solutions
www.rkw-solutions.com
bradeneuropeArthur
Thanks that works quicker.
Do you know how to suppress these items too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Ralf_Krieg
Hello
If you only want to suppress, there's no need to add to SelectSet. You can use the Occurrences in the enum.
	oOcc.Suppress
	'oObjColl.Add(oOcc)
Next
'd.SelectMultiple(oObjColl)
R. Krieg
RKW Solutions
bradeneuropeArthur
But that works slow.
If i suppress thecollection it works fast.
How yo do that with code?
Thanks anyway
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Ralf_Krieg
Hello
Using the ControlDefinition?
	'oOcc.Suppress
	oObjColl.Add(oOcc)
Next
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyCompSuppressionCtxCmd").Execute
R. Krieg
RKW Solutions
bradeneuropeArthur
Thanks.
That I did not think about that!
That will work.
Are there also other methods then using the control definition?
Thanks again @Ralf_Krieg
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
