OK. For me, it is mainly just face value...I use it to know if updates are required in some situations, not so much to save data, but for the peace of mind, because I don't always use both lines together, so the 'Dirty' check, and the Save is sort of a secondary. For instance, if I am going to export several parts in a folder out to STEP files, or generate DXF's from their faces/flat patterns, I often want to ensure several specific preparations are in place before exporting them, but I may not want to save the original model file after the changes, just export the possibly changed files. These changes may already be in place, so no changes may be needed, but others will need to be changed, and I know that certain changes are not usually visible until after an update or rebuild has been performed. I want to be extra sure that the several possible changes have been applied to the documents, if needed, before they get exported, because I don't want to have to open each one and check things after the exports. It just seems like a fairly efficient layer of reassurance in the process. I suppose you could argue that it seems like I'm worried about the changes being present in the exported files, so it is still about saving data, but this is just one scenario among many possibilities. Its actual validity/usefulness in some situations may be questionable and worth further study, but it is a nice property to have available. Good food for thought.
Wesley Crihfield
(Not an Autodesk Employee)
