Insert partnumber on a surface
ctx400
ctx400
Hi there
Isn't it possible to insert Partnumber on a surface as text with ilogic code.
I have found the following on the net and it works almost as desired, but the problem is that the text is not updated if you change Partnumber under iProperties.
I really hope someone has a solution.
This is the code i found:
Sub Main()
'This Is a Ilogic Rule To create a Mark From a textbox For engraving
 '  a reference to the currently active document.
 ' This assumes that it is a part document.
   Dim oPartDoc As PartDocument
   oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
  ' Set a reference to the transient geometry object.
    Dim oTransGeom As TransientGeometry
    oTransGeom = ThisApplication.TransientGeometry
'================ Pasted to pick the face where the Mark has to come ============================
'Select Face and Edges to dimension sketch circles from
Dim oFrontFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Text On")
   ' Create a new sketch on this face
   oSketch = oCompDef.Sketches.AddWithOrientation(oFrontFace, _
   oCompDef.WorkAxes.Item(1), True, True, oCompDef.WorkPoints(1))
   ' Determine where in sketch space the point (0.5,0.5,0) is.
   Dim oCorner As Point2d
   oCorner = oSketch.ModelToSketchSpace(oTransGeom.CreatePoint(0.5, 0.5, 0))
' ===================== Create a Custom Parameter in Iproperties "Partnummer"======================
'Creating Custom IProperty with filenumber in it calling it Partnummer
iProperties.Value("Custom", "Partnummer") = ThisDoc.FileName(False) 'false = without extension
iProperties.Value("Custom", "Partnummer") = (Left(ThisDoc.FileName(False),14))
'Creating a UserParameter Where the Partnummer value Is put In
Dim PropValue As String = iProperties.Value("Custom", "Partnummer")
'updates the user-defined Text Parameter
TagName = PropValue
'================================ Create a textbox in the Sketch to place the Iporp Partnummer ====================
'     Create Text With simple String As Input.  Since this doesn't use
'     any Text Overrides, it will Default To the active Text Style.
Dim oTG As TransientGeometry
   oTG = ThisApplication.TransientGeometry
Dim sText As String
   sText = TagName
   Dim oTextBox As TextBox
   oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(1, 1), sText)
'==================== Creating an Objectcollection to be Marked ======================
    Dim oSketchObjects As ObjectCollection
    oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection
    ' Get all entities in the sketch
Dim oSketchText As TextBox
    For Each oSketchText In oSketch.TextBoxes
        oSketchObjects.Add(oSketchText)
Next
'==================== Creating the Mark on the textbox  ======================
    Dim oMarkFeatures As MarkFeatures
    oMarkFeatures = oCompDef.Features.MarkFeatures
    ' Get a mark style.
    Dim oMarkStyle As MarkStyle
    oMarkStyle = oPartDoc.MarkStyles.Item(1)
' Create mark definition.
Dim oMarkDef As MarkDefinition
oMarkDef = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle)
' Create a mark feature.
Dim oMark As MarkFeature
oMark = oMarkFeatures.Add(oMarkDef)
End Sub
A.Acheson
In the original rule the text is place only as text. What you need is formatted text. In Inventor 2020 only parameters are available as formatted text. If you have a later version perhaps the iproperty is available directly. In that case retrieve the formatted text via the sub routine 'RetrieveFormattedText" below.
You can use a parameter to hold the iproperty. Then a local rule will push iproperty to parameter or just change the parameter directly. Ensure the two don't conflict each other.
This is the line  which creates the formatted text code.
	'Parameter Field (formatted text).
	Dim sText As String = "<Parameter Resolved='True' ComponentIdentifier='" & FullFileName & "' Name='PartNo' Precision='3'>""</Parameter>"
Sub Main()
	' This assumes that currently active document is a part document.
	Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
	Dim FullFileName As String = oPartDoc.FullFileName
	Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
	' Find Sketch named already For marking so the user can delete it
	For Each oSketchCheck As PlanarSketch In oPartCompDef.Sketches
		If oSketchCheck.Name = "MarkingSketch" Then
			MessageBox.Show("A sketch named " & oSketchCheck.Name & " already exists. Please Delete this sketch", "Controle op MarkingSketch")
			Return
	Next
	' Select Face and Edges to place the textbox in a certain direction = Van JelteDejong Forum
	Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Textbox")
	Dim oHorizontalEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Horizontal Edge of Tekeningnummer on Face")
	Dim orignVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select Point (vertex) on the plane")
	Dim testVertex As Vertex = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Select a 2nd Point (vertex) that is on a positive point in the sketch and not on the axes")
	' Add Sketch and set sketch origin point to the stopVertex of the FrontEdge, this is where the TextBox starts
	Dim oSketch As PlanarSketch = oPartCompDef.Sketches.Add(oFace, False)
	oSketch.AxisEntity = oHorizontalEdge
	oSketch.OriginPoint = orignVertex
	oSketch.NaturalAxisDirection = True
	' Check if the testVertex has positive coordinates  = Van JelteDejong Forum
	Dim testPoint As Point2d = oSketch.ModelToSketchSpace(testVertex.Point)
	If (testPoint.X <= 0 Or testPoint.Y <= 0) Then
		oSketch.NaturalAxisDirection = False
	testPoint  = oSketch.ModelToSketchSpace(testVertex.Point)
	Dim positiveQuadrantIsOnPlane = (testPoint.Y >= 0)
	iProperties.Value("Custom", "CustomPartNo") = (Left(ThisDoc.FileName(False), 14))
	' Creating a UserParameter Where the Tekeningnummer value Is put In
	Dim PropValue As String = iProperties.Value("Custom", "CustomPartNo")
	Dim userParams As UserParameters = oPartCompDef.Parameters.UserParameters
	Dim newParam As Parameter
	Try
	newParam = userParams.Item("PartNo")
	Catch
	' Create a parameter and add the iprop
	newParam = userParams.AddByValue("PartNo", PropValue, UnitsTypeEnum.kTextUnits)
	End Try
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oTextBox As Inventor.TextBox
	If (positiveQuadrantIsOnPlane) Then
		oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, 0.5), sText)
	Else
		oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.3, -0.3), sText)
	'Changing Font and/or size
	Dim dTextSize As Double = 0.4 ' value is in cm.  equals .125 in
	'Dim sTextFont As String = "SIMPLEX"
	'Set the text box to Parameter field
	oTextBox.FormattedText = sText
	Dim oSketchObjects As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For Each oSketchText As Inventor.TextBox In oSketch.TextBoxes
	Next
	Dim oMarkFeatures As MarkFeatures = oPartCompDef.Features.MarkFeatures
	' Get a mark style.
	Dim oMarkStyle As MarkStyle = oPartDoc.MarkStyles.Item(1)
	Dim oMarkDef As MarkDefinition = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle)
	Dim oMark As MarkFeature = oMarkFeatures.Add(oMarkDef)
	'Naming the sketch And markfeature For detection In future
	oSketch.Name = "MarkingSketch"
	oMark.Name = "Gravering Tekeningnummer"
	oPartDoc.Save
End Sub
 Rule to update parameter using on change iproperty event trigger
 PartNo = iProperties.Value("Custom", "CustomPartNo")
 RuleParametersOutput()
 InventorVb.DocumentUpdate()
How to retrieve formatted text from a text box
Sub RetrieveFormattedText()
	Dim oSketch As PlanarSketch = oPartCompDef.Sketches(1)
	Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes(1)
	sFormattedText = InputBox("","FormattedText",oTextBox.FormattedText)
End Sub
Regards
Alan
ctx400
Thank you very much it worked perfectly.
I have made a few changes in order to add the revision number as well, but i can't get it to work.
Can you please help me, i'm not that strong in Ilogic.
This is what i got so far but i get an error, BTW i'm running Inventor 2023.
Sub Main()
If oSketchCheck.Name = "Graverings Sketch" Then
MessageBox.Show("En sketch med navnet " & oSketchCheck.Name & " eksisterer allerede. Slet denne sketch først.", "Controle op MarkingSketch")
Return
Next
Try
Catch
End Try
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
iProperties.Value("Custom", "CustomRevNo") = iProperties.Value("Project", "Revision Number")
' Creating a UserParameter Where the Revisionnummer value Is put In
Dim PropValueRev As String = iProperties.Value("Custom", "CustomRevNo")
Dim userParamsRev As UserParameters = oPartCompDef.Parameters.UserParameters
Dim newParamRev As Parameter
Try
newParamRev = userParams.Item("RevNo")
Catch
newParamRev = userParams.AddByValue("RevNo", PropValue, UnitsTypeEnum.kTextUnits)
End Try
'Dim sTextRev As String = newParamRev
Else
oTextBox.FormattedText = sText & "-" & newParamRev
Next
' Get a mark style.
'Dim oMark As MarkFeature = oMarkFeatures.Add(oMarkDef)
oSketch.Name = "Graverings Sketch"
'oMark.Name = "Gravering Part Number"
oPartDoc.Save
End Sub
Event trigger
PartNo = iProperties.Value("Project", "Part Number")
ctx400
Sub Main()
Return
Next
Try
Catch
End Try
Try
Catch
End Try
Else
Next
' Get a mark style.
oPartDoc.Save
End Sub
Event trigger
A.Acheson
A trick here is to use the line Option Explicit On in the Header. This will help identify some errors before you begin. In the error highlighted below it is saying you can't use the "&" which is used in type string with the parmeter object.
So when it jumps to the error line you need to figure out why it isn't a string.  And the reason being is that you are not retrieving the value of the parameter which would be a string but rather the object itself.
Regarding adding the additional rev number. I am assuming your trying to add it in the same text box as the part number. If that is the case you can add both iproperties to one parameter and call it generically a tag.
See below working code to add the parameter and both iproperties.
	Dim TagParam As Parameter
	Try
		TagParam = userParams.Item("Tag")
	Catch
		TagParam = userParams.AddByValue("Tag", "", UnitsTypeEnum.kTextUnits)
	End Try
	TagParam.Value = iProperties.Value("Custom", "CustomPartNo") & "-Rev:" & iProperties.Value("Project", "Revision Number")
	Dim sText As String = "<Parameter Resolved='True' ComponentIdentifier='" & FullFileName & "' Name='Tag' Precision='3'>""</Parameter>"
'Event trigger
Tag = iProperties.Value("Custom", "CustomPartNo")& "-Rev:" & iProperties.Value("Project", "Revision Number")
An alternate method to avoid a second rule is to place the parameter creation and updating  at the start of the rule.  This way you can place the sketch rule on a change in iproperty  event trigger and after creation, if the parameter exist then it updates the parameter value then exits the rule.
	Try
		Return
	Catch
	End Try
Regards
Alan
ctx400
Hi Alan
It works almost perfectly now.
However isn't it possible to run it as an external rule? i can't get it to work.
A.Acheson
Can you post the rule your using and also a screen shot of the more info tab of the error message box?  if your using the newer Inventor it will also show the line number at fault.
Regards
Alan
