How to Save copy as, straight into vault
J.VandeMerckt
Message 1 of 9
J.VandeMerckt
Hi Forum
I have this line of code which saves my configurable part with a custom filename.
It works as intended.
Problem is I would like this file to be checked into the vault instead of saved in file explorer.
Can anyone help me change the code so the part is also checked into the vault.
Dim currentfilename As String
Dim choice As String
Dim length As String
currentfilename = ThisDoc.FileName(False)
choice = Parameter("FixedUnit_Curve")
length = Parameter("FixedUnit_Length")
'custom filepath
'SetTheFilePathHere = "C:\ ... your filepath ..."
'filepath same as the current ipt
SetTheFilePathHere = ThisDoc.Path
SetTheFilenameHere = currentfilename & " - " & choice & " - L" & length & "mm"
ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent, SetTheFilePathHere &"\" & SetTheFilenameHere & ".ipt")
Dim oCtrlDef
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppFileSaveCopyAsCmd")
oCtrlDef.Execute
 Thank you for helping.
BR
Justin
Replies (8)
Message 2 of 9
bradeneuropeArthur
Dim oCtrlDef
oCtrlDef.Execute
Dim oCtrlDefChin
oCtrlDefChin = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
oCtrlDefChin.Execute '.Execute2(True)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
J.VandeMerckt
Hey Arthur
Now the checkin window opens. but only after I close my form.
is there a way to close the form after the Ilogic ran, and then press ok automatically on the checkin window?
Message 4 of 9
J.VandeMerckt
Thank you btw, another step forward!
Message 5 of 9
bradeneuropeArthur
Then you need to use the Vault API.
What version of Vault are you using?
Professional
Basic
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 9
J.VandeMerckt
We're using Vault basic 2020.
Message 7 of 9
bradeneuropeArthur
Vault Basic is not api supported.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 9
J.VandeMerckt
But it would be possible with vault pro or maybe Windchill PLM? (if you're familiar with windchill system)
Message 9 of 9
bradeneuropeArthur
With Vault Professional it is possible yes.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
