How to run code throuh API before Vault Check-In?
Ezekiel12
Message 1 of 12
Ezekiel12
how to run code through API when the User will click check-in to the Vault?
User will click the Check-In button, I need to run some "control" code and after that send it to Vault. If the "control" code fails, I need to stop the Check-in process. (Because user will be notifies to fill in more info to model).
Any idea how to get to check-in through api?
Thx,
Matt
Replies (11)
Message 2 of 12
bradeneuropeArthur
you need to use the pre and post events of the EDM vault add in of inventor.
Read this in the meanwhile:
https://forums.autodesk.com/t5/inventor-customization/use-inventor-vault-add-in-through-inventor-api...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
Ezekiel12
thx for the info. It got us further but there is still problem with it. Can you please help?
We created PRE and POST events (CheckinFileEvents_Pre , CheckinFileEvents_Post) according the code.
The OnLoad function is supposed to register event handler, and it is called from Activate function of the add-in.
HOwever, when pushing Check-in button, no PRE or POST actions are performed.
When debugging, the following error message can be seen during registration of the event handler: "The runtime is unable to evaluate this expression", see the picture:
Message 4 of 12
bradeneuropeArthur
I am developing in Vb.net an I use this:
AddHandler DocumentService.AddFileEvents.Pre, AddressOf AddFileCheckPre
Hope this will help you.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 12
Maxim-CADman77
If not secret what workflow you are expecting to achieve?
For example user tries to check in a huge assembly.... are you going to let him untill each and every component of the assembly passes your checks?
Please vote for Inventor-Idea Text Search within Option Names
Message 6 of 12
Ezekiel12
Not secret at all. Trying to accomplish this (not sucesfull yet):
  • User clicks Check-In
  • The procedure will check several thing in assembly (iproperties by company standard etc...)
  • If correct, check-In will continue
  • If not correct, there will be message window with information what user needs to correct in assembly and the Check*in will abort
Message 7 of 12
Maxim-CADman77
You plan to check only IAMs?
Message 8 of 12
bradeneuropeArthur
@Ezekiel12
Where can I help you further with?
I am using also a add in to do specific things on check in of before or after.
Please let me know what is going wrong exactly?
This should not be any issue...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 12
Ezekiel12
@Maxim-CADman77
Anything (ipts/iams/idw..) as standard check-in dialog.
@bradeneuropeArthur
Well this is where we got stuck 😞
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Microsoft.VisualBasic;
using System.Windows.Forms;
using Autodesk.Connectivity.Explorer.Extensibility;
using Autodesk.DataManagement.Addin.Vault;
using Autodesk.Connectivity.WebServices;
using Autodesk.Connectivity.WebServicesTools;
using VDF = Autodesk.DataManagement.Client.Framework.Vault;
using Connectivity.InventorAddin.EdmAddin;
namespace MyProject.Classes
    public class VaultEventHandler : Autodesk.Connectivity.WebServices.IWebServiceExtension
        public void OnLoad()
            //Autodesk.Connectivity.WebServices.DocumentService.CheckinFileEvents.Pre += new EventHandler<CheckinFileCommandEventArgs>(addfilerunlogic);
            Autodesk.Connectivity.WebServices.DocumentService.CheckinFileEvents.Pre += CheckinFileEvents_Pre;
            Autodesk.Connectivity.WebServices.DocumentService.CheckinFileEvents.Post += CheckinFileEvents_Post;
        private void CheckinFileEvents_Pre(object sender, CheckinFileCommandEventArgs e)
            MessageBox.Show("Pre - Check-in action");
        public void CheckinFileEvents_Post(object sender, Autodesk.Connectivity.WebServices.CheckinFileCommandEventArgs e)
            MessageBox.Show("Post - Check-in action");
Message 10 of 12
bradeneuropeArthur
are you happy with vb.net code too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 12
Ezekiel12
Hi @bradeneuropeArthur
So its a bit frustrating but...
We found out that Vault BASIC does not perform any Document.Service functions. We have tested the application using PROFESSIONAL version where it works well. There is no info about it in documentation.
I have no idea how it will perform on Workgroup... I hope same as Professional.
Message 12 of 12
AlexFielder
Workgroup has (mostly) the same API as Professional whereas Basic doesn't have any API functions AFAIK.
