How to reuse dimensions in a idw file?
Hello everybody!
My issue is: I have similar iparts (Sheet Metal) and I want to make the common dimensions just once in idw file and reuse them when I create a new idw. Is it possible? Do you know some tool I could make this possible?
MechMachineMan
Can you not just accomplish this by replacing the model reference as found in the toolbar (under Manage, I think) ?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Vladimir.Ananyev
Could you look at the following thread:
http://forums.autodesk.com/t5/inventor-customization/creating-drawings-automatic/m-p/5263105#M51758?
It is related to what you need.
cheers
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Curtis_Waguespack
Hi Projetos2013,
Are you talking about creating a table such as this:
If so you can just use the General Table tool to do this.
Create a configuration table
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-474DC835-1011-473A-BF1A-E1B1619091FC
Working with Iparts and iAssembly Drawings
I hope this helps.
Curtis
