how to replace titleblock with a prompted entry one
Hello together,
I have a titleblock in a drawing but i want to delete it and replace it with an another one
which have some prompted entrys. But i dont know how to do it.
i've tried the code below, but i can only insert a titleblock wihtout any prompted entry.
how could I insert a titleblock with prompted entry through API within VB.Net?
Thank you. Richard
 Dim invapp As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
            Dim oSourceDocument As Inventor.DrawingDocument
            oSourceDocument = invapp.ActiveDocument
            Dim oSourceTitleBlockDef1 As Inventor.TitleBlockDefinition
oSourceTitleBlockDef1 = oSourceDocument.TitleBlockDefinitions.Item("jx")
Dim osheet As Inventor.Sheet
            osheet = oSourceDocument.ActiveSheet
 osheet.AddTitleBlock(oSourceTitleBlockDef1)
MechMachineMan
Start by looking here:
"C:\Program Files\Autodesk\Inventor 2016\Local Help\admapi_20_0.chm"
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Does it have to be done through the API?
Maybe the "Drawing Resource Transfer Wizard" supports this?
I do not know for sure as I do not use any prompted title blocks.
you can find it in:
All Programs > Autodesk > Autodesk Inventor 20xx > tools
MechMachineMan
As far as I know, yes. You could also try using other tools to help with
part of the process to avoid writing new stuff.
Justin K
