How to Redefine Sketch with iLogic and Maintain Full-Constraint Status
JBerns
Advisor Advisor
JBerns
Dear Community,
I have a part that I would like to be able to redefine a sketch and maintain its fully-constrained status.
If I redefine the sketch manually, the full-constraint status is maintained regardless of the number of Redefine operations that are performed.
However, when I use iLogic code to redefine the sketch, the full-constraint status is lost after the second operation.
See video here: https://autode.sk/2Zhs7yU
How can I modify the iLogic code to maintain the full-constraint status regardless of the number of Redefine operations performed?
I suspect there is a problem in how I specify the Workplanes, WorkPoints, and WorkAxes. A portion of the iLogic follows. I have attached the part.
Sketch.Redefine(oDef.Sketches.Item(1).Name, partDef.WorkPlanes.Item(i).Name, partDef.WorkPoints(1).Name, partDef.WorkAxes(j).Name, AxisIsX := True, NaturalAxisDirection := True)
Thank you for your time and attention. I look forward to your replies.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
bradeneuropeArthur
Try this:
Public Sub SketchRedef()
    ' Get the active part document.
    Dim partDoc As PartDocument
    partDoc = ThisApplication.ActiveDocument
    Dim partDef As PartComponentDefinition
    partDef = partDoc.ComponentDefinition
    Dim sketch As PlanarSketch
    sketch = partDef.Sketches.Item(1)
    sketch.PlanarEntity = partDef.WorkPlanes.Item(1)
    ThisApplication.ActiveView.Fit
End Sub
or for VBA:
    Set partDoc = ThisApplication.ActiveDocument
    Set partDef = partDoc.ComponentDefinition
    Set sketch = partDef.Sketches.Item(1)
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JBerns
@bradeneuropeArthur,
I should have clarified to review the code in the part.
Were you able to test this code with the existing code in the part?
The interface allows the user to select a Sketch (Work) Plane. After the first selection, the sketch is still fully-constrained. However, after the second plane selection, the full-constraint status is lost. I show this failure in the video. Hope it is helpful.
At a quick glance, I think your code will only  select the XY plane, correct?
Jerry
CAD Administrator
bradeneuropeArthur
My sketch was fully constraint on the initial workplane, and is also after it have been redefined on the new workplane.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
For testing your file, I am missing a derived part!
It is asking for a link.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
JBerns
Would you tell me the file name the link requires or provide a screen capture? I am sure the link can be deleted.
Jerry
CAD Administrator
shastu
What if you want to have the user Redefine an existing sketch to a face that they select?  In VBA please.
