Text Style Customization - Text Inside Two Circles.
Dear Friends;
I have a style question.
Can we create a style that takes texts inside 2 circles in Inventor?
I want to make the drawing up more like the below.
So i try to make a style for my nozzle texts. I want them inside two circles like below.
I searched the text styles but couldn't find what i wanted.
Any ideas if i can customize this style?
Best Regards;
JelteDeJong
I dont know how you could alter a text style in the way you want. But you can make a sketched symbol. It is not as a convenient but it does the job. I created (and attached) an example file with a sketched symbol.
To create a new text place the sketched symbol. It will prompt you for the text you want inside the circles. Then you will need to add a leader.
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you for the contribution.
I am trying to develop a drawing automation template.
I can get all of these nozzle tags(texts) from another program imported automatically. So i am trying to create a style or an Ilogic macro to make them inside two circles.
JelteDeJong
Its possible to add the sketched symbol with a leader. Have a look at this code:
Sub Main()
        Dim doc As DrawingDocument = ThisDoc.Document
        Dim sheet As Sheet = doc.ActiveSheet
        Dim curve As DrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "")
        Dim p1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
        Dim p2 As Point2d = curve.StartPoint
        placeNozzleText(sheet, p1, p2, "L1")
    End Sub
    Public Sub placeNozzleText(sheet As Sheet, p1 As Point2d, p2 As Point2d, text As String) 'view As DrawingView,
        Dim doc As DrawingDocument = sheet.Parent
        Dim inv As Application = doc.Parent
        Dim symbolDdef As SketchedSymbolDefinition = doc.SketchedSymbolDefinitions.Item("nozzle text symbol")
        Dim promptStrings(0) As String
        promptStrings(0) = text
        Dim newSymbol As SketchedSymbol = sheet.SketchedSymbols.Add(symbolDdef, p1, 0, 1, promptStrings)
        Try
            Dim objColletion As ObjectCollection = inv.TransientObjects.CreateObjectCollection()
            objColletion.Add(p1)
            objColletion.Add(p2)
            newSymbol.Leader.AddLeader(objColletion)
        Catch ex As Exception
            MsgBox("Exception was thrown while placing leader. (this can happen if p2 is not a failid point. (like the startpoint of an edge)")
        End Try
    End Sub
Add the rule to the example in my last post.
Add a view.
Run the rule.
Select an edge.
Jelte de Jong
I had error attached when i tried the code.
JelteDeJong
The error messages does not say much. (like so many times wit inventor exception messages.) So i have to guess what is going wrong. I forgot to metion that you need to add the sketched symbol from the file that i did attached earler (and dont change its name). did you add it?
Jelte de Jong
