How to place stamp/symbol automatically at bottom righthand corner of drawing border?
Jason.Rugg
Jason.Rugg
I have a symbol/stamp that is being inserted onto drawings when releasing them. The stamp gets placed on the right hand border of the drawing but this only works for a certain drawing template since it is using a 0,0 insertion point (which is the bottom left hand corner of the drawing sheet. To allow this to work with different drawing templates/sizes I need the code to be able to detect the bottom right hand corner of the drawing sheet automatically and use that point as the insertion point for the stamp, is that possible? Below is the portion of my code how it is currently working.
Option Explicit On
Imports System.IO
Sub Main
	Call PlaceStamp()
	Call CreatePDF()
	'Call Printing()
	Call Email()
	Call DeleteStamp()
End Sub
Sub PlaceStamp
	' reference to the sketched symbol definition.
	Dim oSymbolDef As SketchedSymbolDefinition
	oSymbolDef = ThisDrawing.Document.SketchedSymbolDefinitions.Item("Drawing Release Stamp")
	Dim oSheet As Sheet = ThisDrawing.Document.ActiveSheet
	'create insertion point, coordinates - in cm !
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oPoint As Point2d = oTG.CreatePoint2d(0, 0)
	' Add an instance of the sketched symbol definition to the sheet.
	' Rotate angle = 0 radians,  scale = 1 when adding
	Dim sPromptStrings(4) As String
	'Get prompt values, this example just uses hardcoded values
	sPromptStrings(0) = InputBox("Enter Signature", "iLogic", "")
	sPromptStrings(1) = InputBox("Enter Date", "iLogic", "")
	sPromptStrings(2) = InputBox("Enter Job #", "iLogic", "")
	sPromptStrings(3) = InputBox("Enter Rev", "iLogic", "")
	sPromptStrings(4) = InputBox("If this is a revised drawing, type 'REVISED DRAWING'", "iLogic", "")
	Dim oSymbol As SketchedSymbol
	oSymbol = oSheet.SketchedSymbols.Add(oSymbolDef, oPoint, 0, 1, sPromptStrings)
End Sub
Sub DeleteStamp
bradeneuropeArthur
Use "border maxpoint x" and "border minpunt y" to find the coördinaten!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Jason.Rugg
@bradeneuropeArthur Sounds good but I am unfamiliar with how to that.
WCrihfield
Dim oBorder As Border = ThisDrawing.Document.ActiveSheet.Border
oX = oBorder.RangeBox.MaxPoint.X
oY = oBorder.RangeBox.MinPoint.Y
oPosition = ThisApplication.TransientGeometry.CreatePoint2d(oX, oY)
Wesley Crihfield
(Not an Autodesk Employee)
Jason.Rugg
@WCrihfield If I place that bit of code in a rule with the code that places the stamp it seems to work as expected (as shown below). Bigger code shown further down with errors.
Working Rule
Sub Main
	Dim oPoint As Point2d = oTG.CreatePoint2d(oX, oY)
End Sub
Bigger Code not working with errors, not sure what the difference is and why it is not working in the bigger picture.2022-12-05 13_28_37-Edit Rule_ Drawing Release.png
Option Explicit On
Imports System.IO
End Function
Sub PlaceStamp
End Sub
Sub DeleteStamp
WCrihfield
I should have 'declared' the variables I was using there to avoid 'strict' setting warnings, and used your "oPoint" variable line of code, instead of using a different variable name for that Point2d object it was creating, because you are still using the oPoint variable in your 'SketchedSymbols.Add()' method, instead of the new oPosition variable.  Here is how that last Sub should have been updated:
Sub PlaceStamp
	Dim oBorder As Border = oSheet.Border 'can be Nothing, good to check first
    Dim oX As Double = oBorder.RangeBox.MaxPoint.X
	Dim oY As Double = oBorder.RangeBox.MinPoint.Y
End Sub
Wesley Crihfield
bradeneuropeArthur
	'Dim oSymbolDef As SketchedSymbolDefinition
	'oSymbolDef = ThisDrawing.Document.SketchedSymbolDefinitions.Item("Drawing Release Stamp")
	oSymbol = oSheet.SketchedSymbols.Item(1)
	oSymbol.Position= oPoint
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
