Multiple hole table renumbering while retaining hole groups
jake.mckelvieBQFM9
jake.mckelvieBQFM9
I have created a rule where multiple hole tables are renumbered so that the numbering continues through multiple tables. However, I want the lettering to increase each time a new hole group (hole with different description), could anyone advise on what needs to be written for this to happen?
Sorry if this is an easy fix, i'm still new to ilogic
JelteDeJong
There is some bug but I need to go. But maybe it's good enough for you.
If (ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject) Then
    MsgBox("This only works in drawings")
    Return
Dim doc As DrawingDocument = ThisDoc.Document
Dim letter As String = "A"
Dim number As Integer = 0
'You might need to change the column number
Dim descriptionColumnNumber = 4
Dim description = doc.Sheets.Item(1).HoleTables.Item(1).HoleTableRows.Item(1).Item(descriptionColumnNumber).Text
For Each sheet As Sheet In doc.Sheets
    For Each table As HoleTable In sheet.HoleTables
        number += 0
        For Each row As HoleTableRow In table.HoleTableRows
            Dim nextDescription = row.Item(descriptionColumnNumber).Text
            If (Not description.Equals(nextDescription)) Then
                letter = Chr(Asc(letter) + 1)
                number = 0
                description = nextDescription
            number += 1
            row.HoleTag.Text = letter & number
        Next
    Next
Jelte de Jong
Blog: hjalte.nl - github.com
jake.mckelvieBQFM9
Thanks for your response on this, I have tried to incorporate your code, however I can't seem to eradicate the bugs unfortunately.
Could you see if there's any more you can do please?
Thanks!
JelteDeJong
I think I found a bug in the inventor API. ( @adam.nagy ) looping over all rows in a table with:
gives a different result than looping with:
For i = 1 To table.HoleTableRows.Count
If I use " for each ..." on the rows of the 1e table then I also get the rows of the 2e table.
As a workaround, you can use the "for i = ..." loop to get each row. then your rule would look like this:
    Return
            Dim row = table.HoleTableRows.Item(i)
                number = 0
            number += 1
        Next
    Next
Next
Jelte de Jong
jake.mckelvieBQFM9
That has worked perfectly, thanks for all your help!
jake.mckelvieBQFM9
Sorry one more thing.
I tried the code in one instance (See instance 1 snapshot) and it worked perfectly, however I have just used it in another drawing and it's carried on the sequence between hole tables (See instance 2 snapshot).
Any idea on why this would be happening?
Thanks in advance
