How to modify base components in derived part
Damian_Apex
Damian_Apex
I have a derived part that has 1 assembly and some parts inside it. From the level of the derived part I would like to get to this assembly and to be able to modify it. For example, to be able to use the command "component.replace".
I think I need to transfer somehow "DerivedAssemblyComponent" to "AssemblyDocument".
Sub main
Dim oPart  As PartDocument = ThisDoc.Document
Dim oRef As Document = oPart.ReferencedDocuments.Item(1)
Dim oDerAssembly As DerivedAssemblyComponent
oDerAssembly = oPart.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Item(1) Trace.Write(oDerAssembly.Name) For Each oPart In oRef.AllReferencedDocuments Trace.Write("ALL: " & oPart.FullFileName) Next End Sub
SometimesInventorMakesMeAngry
Sub main
dim refAssembly as AssemblyDocument = oPart.ReferencedDocuments.Item(1)
Damian_Apex
I am getting such an error
Sub main
'Do what you need to do with refAssembly here
End Sub
