Create a Rectangular pattern of solids with iLogic
ejaL9K8H
Message 1 of 13
ejaL9K8H
Hi
I having problems achieving a rectangular pattern of solids with ilogic. This is my code so far.
' Create new pattern of solids
Dim oPD As PartDocument = ThisDoc.Document
Dim oPCD As PartComponentDefinition = oPD.ComponentDefinition
Dim Zaxis As Object = oPCD.WorkAxes.Item(3)' Select Z Axis
Dim SB_ObjCol As ObjectCollection
	SB_ObjCol = ThisApplication.TransientObjects.CreateObjectCollection
		For i = 1 To 5 ' Add the first 5 solid bodies to the object collection
			SurfBody = oPCD.SurfaceBodies.Item(i)
			SB_ObjCol.Add(SurfBody)
		Next
Dim qtypattern As Integer
qtypattern = 2 ' Define Number of Pattern
DistPrompt1 = 2000 ' Define Distance of Pattern
Dim oRecFeat As RectangularPatternFeature
oRecFeat = oPCD.Features.RectangularPatternFeatures.Add(SB_ObjCol, Zaxis, True, qtypattern, DistPrompt1, kDefault, , , , , , , , kAdjustToModelCompute, kAdjustToDirection1)
oRecFeat.PatternElements.PatternOfBody = True
oRecFeat.Definition.Operation = kNewBodyOperation
'rename pattern
oRecFeat.Name = "SolidPattern"
Any suggestions?
Best regards Emil Jakobsen
Replies (12)
Message 2 of 13
ejaL9K8H
Alternatively a Rectangular Pattern Feature should be adjusted - But I cant get this to work either...
' Adjust solid pattern
		Next
Dim ComDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPattern As RectangularPatternFeature = ComDef.Features.RectangularPatternFeatures.Item("SolidPattern")
'Trying to adjust the pattern
oPattern.SetAffectedBodies = SB_ObjCol
'SurfaceBodies is ReadOnly
'oPattern.SurfaceBodies = SB_ObjCol
Message 3 of 13
theo.bot
I'm not sure why you used the Add methode, because you can only use a Addbydefinition to create that pattern accoring to the API help.
When You first create a definition then you can add a collection of solids or a collection of features. here is a small sample:
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim oComp As PartComponentDefinition
oComdef = oDoc.ComponentDefinition
Dim oSolids As ObjectCollection
	oSolids = ThisApplication.TransientObjects.CreateObjectCollection
oSolids.Add(oComdef.SurfaceBodies(1))
oSolids.Add(oComdef.SurfaceBodies(3))
Dim oRectangularPatterndef As RectangularPatternFeatureDefinition
oRectangularPatterndef = oComdef.Features.RectangularPatternFeatures.CreateDefinition(oSolids, oComdef.WorkAxes.Item("X Axis"), True, 3, 50)
oComdef.Features.RectangularPatternFeatures.AddByDefinition(oRectangularPatterndef)
Message 4 of 13
ejaL9K8H
I still get an error:
Error in rule: Create new pattern, in document: Lamel.ipt
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.RectangularPatternFeature'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{58B0C13D-27CC-4F06-93FD-0524B69E6578}' failed due to the following error: En sådan grænseflade understøttes ikke (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
With this code:
		Next
oRecFeat = oPCD.Features.RectangularPatternFeatures.CreateDefinition(SB_ObjCol, Zaxis, True, 3, 2000,kDefault)
oPCD.Features.RectangularPatternFeatures.AddByDefinition(oRecFeat)
'rename pattern
Message 5 of 13
theo.bot
Can you share your model?
Message 6 of 13
ejaL9K8H
Does this make sense?
You can unsuppress the rectangular pattern with the name "What I want" to see what I am aiming for
Message 7 of 13
theo.bot
You where almost there 🙂
But you forgot to change the definition of oRecFeat to RectangularPatternFeatureDefinition
Also the renaming can't be done on the definition. do first you need to define the rectangularpatternfeature
Also be aware you entered a value of 2000, meaning you will use the databaseunits ("cm"). Use the Unit of measure to work with different units.
		Next
'Dim oRecFeat As RectangularPatternFeature
Dim oRecFeat As RectangularPatternFeatureDefinition
oPattern = oPCD.Features.RectangularPatternFeatures.AddByDefinition(oRecFeat)
'rename pattern
oPattern.Name = "SolidPattern"
Message 8 of 13
ejaL9K8H
Thanks a lot!
But when i am copy ans pasting into a new rule, I keep getting an error:
System.Runtime.InteropServices.COMException (0x80004005): Uspecificeret fejl (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.RectangularPatternFeatures.AddByDefinition(RectangularPatternFeatureDefinition Definition)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 9 of 13
ejaL9K8H
I think my problem is that I am having troublle with creating a ObjectColection with more than one solid.
This code with one solid works fine:
' Try To delete previous pattern, just For testing
Try
ThisApplication.ActiveDocument.ComponentDefinition.Features("Pattern").delete
InventorVb.DocumentUpdate()
Catch
End Try
Dim oPD As PartDocument = ThisApplication.ActiveDocument
Dim oPCD As PartComponentDefinition= oPD.ComponentDefinition
Dim oSolid1 As SurfaceBody = oPCD.SurfaceBodies(2)
Dim oBjCol As ObjectCollection= ThisApplication.TransientObjects.CreateObjectCollection
	oBjCol.Add(oSolid1)
Dim oPath As Object = oPCD.WorkAxes.Item(3)
Dim oRectDef As RectangularPatternFeatureDefinition =  oPCD.Features.RectangularPatternFeatures.CreateDefinition(oBjCol, oPath, True, 3, 12)
oRectDef.Operation = kNewBodyOperation
Dim oRecFeat As RectangularPatternFeature = oPCD.Features.RectangularPatternFeatures.AddByDefinition(oRectDef)
oRecFeat.Name = "Pattern"
But by adding 2 lines of code (2 solids) the code is giving an error:
Try
Catch
End Try
Dim oSolid2 As SurfaceBody = oPCD.SurfaceBodies(3) ' Adding this line
	oBjCol.Add(oSolid1)
	oBjCol.Add(oSolid2) ' Adding this line
Message 10 of 13
theo.bot
Hmmm... strange..
I think it's a R2020 problem, because it works fine in R2021 and R2022. I can reproduce your error in R2020.
Currently update R202 to the latest update, see if this helps.
Message 11 of 13
theo.bot
I think I found a workaround for R2020.
We will add the solids after the definition creation.
Try
Catch
End Try
	oBjCol.Add(oSolid1)
For i = 2 To 5 ' Add the first 5 solid bodies to the object collection
oRectDef.ParentFeatures.Add(oPCD.SurfaceBodies.Item(i))
next
Message 12 of 13
ejaL9K8H
It is still not working in R2020...
I think you need to add
But there is no add procedure...
Message 13 of 13
theo.bot
Sorry, I was testing this to quickly between my other work. Never have three version of inventor open, that's asking for mistakes :-). Your right this also didn't work for R2020. I think you better start a support case, maybe it's a bug in the API of R2020.
