Ilogic rule for a particular sheet to find the dimension overrides
ArunS2DHBM
ArunS2DHBM
I have 3 sheets names, Assy:1, Body:1 and Nameplate:1
i want a rule for sheet name Assy:1 to find the override in any dimension having "Hold" mentioned in it.
if so then my parameter "Status" should carry a value "X" else it should be "-"
Please help me with the code
Thanks in advance.
theo.bot
The first step is define the sheet in your drawing, secondly loop thru all dimension on your sheet. You can check if the dimension text contains a particular text and is the hidevalue is true of false. here's a small sample assuming you have that parameter "Status" in your drawing document.:
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Sheet
oSheet = oDoc.Sheets("Assy:1")
Dim oFound As Boolean
oFound = False
'loop thru all dimensions on sheet
For Each oDim As DrawingDimension In oSheet.DrawingDimensions
	'check if HideValue is true
	If oDim.HideValue = True Then
		'check if dimension text contains "hold"
		If oDim.Text.Text.Contains("Hold") = True Then
			oFound = True
			Exit For
Next
If oFound = True Then
	Status = "X"
Else
	Status = "-"
ArunS2DHBM
Thanks for the code. it works perfectly.
