How to import Customization Settings file with vba?
lzs013
lzs013
How to import Customization Settings Snipaste_2018-11-29_22-00-36.pngfile(xml file) with vba?
bradeneuropeArthur
Take a look at this, maybe this is on option for you?
"C:\Program Files\Autodesk\Inventor 20##\Bin\Inventor.exe" /IMPORTOPTIONS="C:\YYYYYYY.xml"
https://beinginventive.typepad.com/being-inventive/2010/09/start-inventor-with-fixed-application-opt...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
j_steenbergen
This isn't a VBA command? I tried the solution mentioned above but this didn't work.
Is there any way to import the ribbon customization file using VBA?
