How to exit sub, nested in for loop?
Probably a very simple solution to this problem, but I cannot for the life of me figure out how to accomplish this.
I have a rule that exports a named .dwg to a named folder. This helps me stay organized when batching out parts pre-CNC.
This is all fine except I can't figure out how to get a true "cancel" out my rule. When exporting iParts, I have a for loop that iterates through each member. In that loop a sub is called to do the exporting. However, if I have exported the parts I need, or just want to cancel out early, I can't get out of the loop until all of the members have run. I tried "Return", "Exit Sub" and "GoTo" and couldn't get it. I only managed to exit the sub, but still have to finish looping.
Maybe I'm just approaching the whole problem wrong.
Thoughts appreciated.
'Funnybus
Sub Main
Dim oDocPath As String = ThisDoc.Path
Dim oDoc As Document = ThisDoc.Document
Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
    Dim sPrtPath As String = (Left(oDocPath,InStrRev(oDocPath, "\"))&"_CNC")
        If Not System.IO.Directory.Exists(sPrtPath) Then
            MessageBox.Show("Could not locate CNC folder for this project." & vbLf & vbLf & sPrtPath & vbLf, "Error", MessageBoxButtons.OKCancel, MessageBoxIcon.Exclamation)
            Return
        If oDoc.DocumentType <> kPartDocumentObject Then
            MessageBox.Show("Rule can only be run from a part document.", "Error", MessageBoxButtons.OKCancel, MessageBoxIcon.Exclamation)
            Exit Sub
        If oCompDef.IsiPartFactory Then
			Export2iPart(oCompDef, sPrtPath)
        Else
            Export2Part(sPrtPath)
End Sub
Private Sub Export2Part (sPrtPath As String)
	Dim sPrtNum As String = iProperties.Value("Project", "Description")
	YesNo(sPrtNum, sPrtPath)
End Sub
Private Sub Export2iPart (oCompDef As ComponentDefinition, sPrtPath As String)
Dim oFactory As iPartFactory = oCompDef.iPartFactory
    For Each oRow As iPartTableRow In oFactory.TableRows
        Dim sPrtNum As String = oRow.memberName
        iPart.ChangeRow("", sPrtNum)
	Next
End Sub
Private Sub YesNo (sPrtNum As String, sPrtPath As String)
Dim sPrtFldr As String = sPrtPath & "\" & sPrtNum
Dim sPrtDwg As String = sPrtFldr & "\" & sPrtNum & ".dwg"
oMSG = MessageBox.Show("Create CNC?" & vbLf & vbLf & "Part Number: " & sPrtNum & vbLf & vbLf & sPrtDwg & vbLf, "Export to CNC", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
	If oMSG = vbYes Then
		If System.IO.Directory.Exists(sPrtFldr)
			oMSG2 = MessageBox.Show("Existing folder found: " & vbLf & vbLf & sPrtFldr & vbLf & vbLf & "Overwrite existing folder?" & vbLf, "Existing Folder Found", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Exclamation, MessageBoxDefaultButton.Button1)
				If oMSG2 = vbYes Then
					System.IO.Directory.CreateDirectory(sPrtFldr)
					Dim oPrt As PartDocument = ThisApplication.ActiveDocument
					oPrt.SaveAs(sPrtDwg, True)
				Else If oMSG2 = vbCancel Then
					'End rule
		Else
	Else If oMSG = vbCancel Then
		'End rule
End Sub
MechMachineMan
Your issue is that you have no return value and no prompting to control the for loop; which is the control structure you need control to.
Either you need to modify your code to have the prompt within the for loop - as well as the test and exit code -, or do as below and carry along a "controlling" variable to be able to return information to the controlling loop, so you can test it there.
Sub Main
            Return
            Exit Sub
        Else
End Sub
	YesNo(sPrtNum, sPrtPath, True)
End Sub
     Dim boolContinue As boolean = True
For Each oRow As iPartTableRow In oFactory.TableRows Dim sPrtNum As String = oRow.memberName iPart.ChangeRow("", sPrtNum) YesNo(sPrtNum, sPrtPath, boolContinue)
If boolContinue = False Then
Exit Sub
End if Next End Sub Private Sub YesNo (sPrtNum As String, sPrtPath As String, ByRef boolContinue As Boolean) Dim sPrtFldr As String = sPrtPath & "\" & sPrtNum Dim sPrtDwg As String = sPrtFldr & "\" & sPrtNum & ".dwg" oMSG = MessageBox.Show("Create CNC?" & vbLf & vbLf & "Part Number: " & sPrtNum & vbLf & vbLf & sPrtDwg & vbLf, "Export to CNC", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) If oMSG = vbYes Then If System.IO.Directory.Exists(sPrtFldr) oMSG2 = MessageBox.Show("Existing folder found: " & vbLf & vbLf & sPrtFldr & vbLf & vbLf & "Overwrite existing folder?" & vbLf, "Existing Folder Found", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Exclamation, MessageBoxDefaultButton.Button1) If oMSG2 = vbYes Then System.IO.Directory.CreateDirectory(sPrtFldr) Dim oPrt As PartDocument = ThisApplication.ActiveDocument oPrt.SaveAs(sPrtDwg, True) Else If oMSG2 = vbCancel Then boolContinue = False End If Else System.IO.Directory.CreateDirectory(sPrtFldr) Dim oPrt As PartDocument = ThisApplication.ActiveDocument oPrt.SaveAs(sPrtDwg, True) End If Else If oMSG = vbCancel Then
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
MechMachineMan,
Good stuff, I appreciate the help. Carrying a controlling variable seems like the way to go.
Thanks!
