iLogic to return specific folder in a path
YannickEnrico
Advisor Advisor
YannickEnrico
Hi there.
I would like to know if there is a way to make iLogic return say folder no. 4 of a file that is 6 folders down in the tree?
Currently I'm using folderpath, but that returns the folder of the file.
My folder tree works like this:
C:/WF/Designs/CUSTOMER/ORDERNO/FRAMEGENERATOR/FRAME
I would like to return Customer and Orderno and write it to a custom iProperty.
With my current setup, it naturally returns FRAMEGENERATOR and FRAME for frame generator parts
I know what isn't possible:
It isn't possible to cover everything by no. of characters from the start
It isn't possible to cover everything by no. of characters from the end.
It isn't possible to cover everything by parent folders, since frame parts won't return the proper names, then.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
YannickEnrico
It would appear I figured it out.
Thanks anyhow!
'get filepath
filePath = ThisDoc.Path
'separate into array by directory separator
filePathArray = Split(filePath, System.IO.Path.DirectorySeparatorChar)
'C=0, WF=1, Designs=2, Customer=3, OrderNo=4
filePathOrderNo = filePathArray(4)
filePathCustomer = filePathArray(3)
iProperties.Value("Custom", "Ordrenummer")=filePathOrderNo
iProperties.Value("Project", "Project")=filePathCustomer
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
JelteDeJong
the following code splits the folderpath in sepparated strings. From there you can get the folder names that you need
'get the full file name of the this document
Dim folderpath As String = ThisDoc.PathAndFileName(False)
'split the "full file name" in folder foldernames
Dim folders As String() = folderpath.split("\")
'get the data you are looking for.
'Pay attension that ilogic start counting by 0
'C:/WF/Designs/CUSTOMER/ORDERNO/FRAMEGENERATOR/FRAME
'0  1    2        3        4          5          6
Dim Customer As String = folders(3)
Dim Orderno As String = folders(4)
iProperties.Value("Project", "Description") = Customer + " - " + Orderno
Jelte de Jong
Blog: hjalte.nl - github.com
