How to create a copy of Positional Representation with iLogic
I am attempting to make a simple copy of an existing Positional Representation with iLogic. I am wanting to emulate RMB clicking on an existing Pos Rep and clicking Copy. I have created rules for New, Show Current, Rename but cant figure out Copy. Any help will be appreciated. Thanks in advance Colin
MechMachineMan
This is what reference material is for.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-211C1C76-32BF-4573-B938-AF51C87F2E0E
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thank you for the feed back. very helpful. Pleased to see this not tucked away in 2018 as it is in 2017 help system. I was definitely over complicating my efforts to accomplish this and this morning it took 2 minutes and solved.
thanks again Justin
