Building my first Add-in problem 1
j.romo
j.romo
Hello, I'm trying to develop my first add-in, i have some experience with Ilogic and right now I'm struggling with te basics of it.
The add-in will work for old inventor files  or imported components, so we can add some custom Iproperties.
the problem i will asume is very basic but i cant seem to figure out how to structure the create property...
using visual studio 2015
here is my code
Private Sub Button3_Click(sender As Object, e As EventArgs) Handles Button3.Click
'Public Sub CreateCustomProperties()
' Get the active document.
Dim invDoc As Document
invDoc = _invApp.ActiveDocument
' Get the user defined (custom) property set.
Dim invCustomPropertySet As PropertySet
invCustomPropertySet = invDoc.PropertySets.Item("Inventor User Defined Properties")
' Declare some variables that will contain the various values.
Dim strProv As String
Dim strTel As String
Dim strMail As String
Dim strTe As String
' Set values for the variables.
strProv = "AGREGAR PROVEEDOR"
strTel = "AGREGAR TELEFONO"
strMail = "AGREGAR CORREO ELECTRONICO"
strTe = "AGREGAR TIEMPO DE ENTREGA"
' Create the properties.
Dim invProperty As [Property]
invProperty = invCustomPropertySet.Add(strProv, "PROVEEDOR")
invProperty = invCustomPropertySet.Add(strTel, "TELEFONO")
invProperty = invCustomPropertySet.Add(strMail, "CORREO")
invProperty = invCustomPropertySet.Add(strTe, "T.E")
End Sub
Owner2229
Your code is correct, except the property definition:
    Dim oDoc As Document = _invApp.ActiveDocument
    Dim oProSet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
    ' Declare some variables that will contain the various values and set values for the variables.
    Dim strProv As String = "AGREGAR PROVEEDOR"
    Dim strTel As String = "AGREGAR TELEFONO"
    Dim strMail As String = "AGREGAR CORREO ELECTRONICO"
    Dim strTe As String = "AGREGAR TIEMPO DE ENTREGA"
    Dim invProperty As Inventor.Property
    invProperty = oProSet.Add(strProv, "PROVEEDOR")
    invProperty = oProSet.Add(strTel, "TELEFONO")
    invProperty = oProSet.Add(strMail, "CORREO")
    invProperty = oProSet.Add(strTe, "T.E")
End Sub
Also, if you only want to add the iPropery (and not work with it further), you can do it without declaration, e.g.:
You should also check for existing iProperty:
    GetProperty(oProSet, "PROVEEDOR", strProv)
    GetProperty(oProSet, "TELEFONO", strTel)
    GetProperty(oProSet, "CORREO", strMail)
    GetProperty(oProSet, "T.E", strTe)
End Sub
Private Function GetProperty(oProSet As PropertySet, sName As String, Optional sValue As String = "") As Inventor.Property
Dim iPro As Inventor.Property
Try
iPro = oProSet(sName)
Catch
iPro = oProSet.Add(sValue, sName)
End Try
Return iPro
End Function
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
j.romo
thank you Mike worked as a charm....Smiley Very Happy
ill give it a study to learn from what I did wrong
thanks
Owner2229
Inventor.Property
instead of
[Property]
Mike
