How to create a COM object for the Task-Scheduler!
bradeneuropeArthur
Mentor Mentor
Message 1 of 1
bradeneuropeArthur
How to create a COM object for the Task-Scheduler using ServiceModuleInterfaceDef.tlb?
Are there any examples available?
Found this in the Help but I need some more support on this:
"Definine COM interface
If you want to use the custom task functionality with COM, first create a COM component which is derived from IServiceModules. The file ServiceModuleInterfaceDef.tlb, which defines the COM interface -- IServiceModules, is installed at Program Files
 Inventor [version]
 Bin. There are five methods defined in the interface:
  • HRESULT StartTask() -- Must be implemented to start the actual custom work at a scheduled time.
  • HRESULT KillTask(void) -- Reserved.
  • HRESULT SetOptions ([in] VARIANT varOptions) -- Passes in the options specified on the UI.
  • HRESULT GetInventorProcessID([in, out] SAFEARRAY(long)* ppsaInventorProcIDs) -- Retrieves Inventor process IDs for monitor usage.
  • HRESULT SetCommand)(*[in} enumTaskCmd enumTaskCmd) -- Sets the commands for pause, stop, and resume task.
Note: Reference the file ServiceModuleInterfaceDef.tlb within your project for access to the COM interface."
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (0)
