This is the code from the help file:
Derived Parts and Assemblies API Sample
Description
This sample demonstrates the use of the API to create derived parts and assemblies.
Code Samples
VBA
This example used is a simple case of a part subtracted from a mold. To simplify setup, the program creates the parts representing the part and the mold. It then uses derived parts and assemblies to scale the part and subtract it from the mold.Public Sub MoldBaseSample()
' Initialize the string that defines the directory where the
' files will be created.
Dim sFilePath As String
sFilePath = "C:\Temp\"
' Call the functions to create the parts that represent the
' molded part and the mold base.
Call CreateMoldPart(sFilePath & "MoldPart.ipt")
Call CreateMoldBase(sFilePath & "MoldBase.ipt")
' Create a new part file to derive the mold part in.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Create a derived definition for the molded part.
Dim oDerivedPartDef As DerivedPartUniformScaleDef
Set oDerivedPartDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(sFilePath & "MoldPart.ipt")
' Set the scale to use.
oDerivedPartDef.ScaleFactor = 1.1
' We could set other options for the derived part using the derived part definition.
' In this case the defaults are good except for the scale which we changed.
' Create the derived part.
Call oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
' Save and close the part. Uses SilentOperation to bypass the save dialog.
ThisApplication.SilentOperation = True
Call oPartDoc.SaveAs(sFilePath & "ScaledMoldPart.ipt", False)
ThisApplication.SilentOperation = False
oPartDoc.Close
' Create a new assembly file to put the mold base and scaled part together.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.Documents.Add(kAssemblyDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kAssemblyDocumentObject))
' Create the matrix used to define the position of the occurrences. When a new
' matrix is created it is initialized to an identity matrix. This will cause
' parts to be placed into the assembly in the same location that are in part space.
Dim oMatrix As Matrix
Set oMatrix = ThisApplication.TransientGeometry.CreateMatrix
' Place the mold base.
Dim oOcc As ComponentOccurrence
Set oOcc = oAsmDoc.ComponentDefinition.Occurrences.Add(sFilePath & "MoldBase.ipt", oMatrix)
' Rename the occurrence. This sample uses the name to identify the occurrence later.
' This isn't the only method that could be used, but is one of the simplest.
oOcc.Name = "Mold Base"
' Place the scaled part.
Set oOcc = oAsmDoc.ComponentDefinition.Occurrences.Add(sFilePath & "ScaledMoldPart.ipt", oMatrix)
oOcc.Name = "Mold Part"
' Save and close the assembly.
Call oAsmDoc.SaveAs(sFilePath & "MoldSample.iam", False)
oAsmDoc.Close
' Create a new part to derive the assembly into, subtracting the part from the mold base.
' Create a derived definition for the molded assembly.
Dim oDerivedAsmDef As DerivedAssemblyDefinition
Set oDerivedAsmDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(sFilePath & "MoldSample.iam")
' Set the part to be subtracted.
oDerivedAsmDef.Occurrences.Item("Mold Part").InclusionOption = kDerivedSubtractAll
' Create the derived assembly.
Call oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAsmDef)
End Sub
' Sub to create the part representing the molded part.
Private Sub CreateMoldPart(Filename As String)
' Create a new part document using the default part template.
' Create a new sketch on the XY base workplane.
Dim oSketch As PlanarSketch
Set oSketch = oPartDoc.ComponentDefinition.Sketches.Add(oPartDoc.ComponentDefinition.WorkPlanes(3))
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Draw the geometry defining the shape of the part.
Dim oPoints As ObjectCollection
Set oPoints = ThisApplication.TransientObjects.CreateObjectCollection
oPoints.Add oTG.CreatePoint2d(-5, 0)
oPoints.Add oTG.CreatePoint2d(-4, 3)
oPoints.Add oTG.CreatePoint2d(-2, 4)
oPoints.Add oTG.CreatePoint2d(0, 3)
oPoints.Add oTG.CreatePoint2d(3, 4)
oPoints.Add oTG.CreatePoint2d(4, 2)
oPoints.Add oTG.CreatePoint2d(5, 0)
Dim oSpline As SketchSpline
Set oSpline = oSketch.SketchSplines.Add(oPoints)
oSpline.FitMethod = kSweetSplineFit
Dim oLine As SketchLine
Set oLine = oSketch.SketchLines.AddByTwoPoints(oSpline.FitPoint(1), oSpline.FitPoint(oSpline.FitPointCount))
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
' Create a revolved feature.
Call oPartDoc.ComponentDefinition.Features.RevolveFeatures.AddFull(oProfile, oLine, kJoinOperation)
' Save and close the document.
Call oPartDoc.SaveAs(Filename, False)
oPartDoc.Close
End Sub
' Sub to create the part representing the mold base.
Private Sub CreateMoldBase(Filename As String)
Call oSketch.SketchLines.AddAsTwoPointRectangle(oTG.CreatePoint2d(-6, -5), oTG.CreatePoint2d(6, 5))
' Create an extruded feature.
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
Dim oExtrudeDef As ExtrudeDefinition
Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
Call oExtrudeDef.SetDistanceExtent(5, kNegativeExtentDirection)
Call oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
oPartDoc.Close
End Sub
