05:44 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All,
I have a rule (which is working prefectly) to calculate and report sweep length in a Part file (thanks to Rob van der Veek from FORUM Inventor Users Netherland), but, at first I would like to check if a specific named feature (Sweep1, e.g.) exists in a part file, and then, run that "length rule"...
If that feature don't exist, I do nothing...
The Sweep Length Rule is:
'DIM_SWEEP_R1 ' 'Set a reference to the active part document Dim oDoc As PartDocument oDoc = ThisApplication.ActiveEditDocument Dim oDef As PartComponentDefinition oDef = oDoc.ComponentDefinition ' Set a reference to the selected feature. Make sure you name the Sweep "Sweep1" or change this variable to match the Sweep you wish to calculate Dim oSweep As SweepFeature oSweep = oDef.Features.SweepFeatures.Item("Sweep1") ' Get the centroid of the sweep profile in sketch space Dim oProfileOrigin As Point2d oProfileOrigin = oSweep.Profile.RegionProperties.Centroid ' Transform the centroid from sketch space to model space Dim oProfileOrigin3D As Point oProfileOrigin3D = oSweep.Profile.Parent.SketchToModelSpace(oProfileOrigin) ' Get the set of curves that represent the true path of the sweep Dim oCurves As ObjectsEnumerator oCurves = oDef.Features.SweepFeatures.GetTruePath(oSweep.Path, oProfileOrigin3D) Dim TotalLength As Double TotalLength = 0 Dim oCurve As Object For Each oCurve In oCurves Dim oCurveEval As CurveEvaluator oCurveEval = oCurve.Evaluator Dim MinParam As Double Dim MaxParam As Double Dim length As Double Call oCurveEval.GetParamExtents(MinParam, MaxParam) Call oCurveEval.GetLengthAtParam(MinParam, MaxParam, lengthp) TotalLength = TotalLength + lengthp Next Dim oparams As Parameters Dim oparam As Parameter oparams = oDoc.ComponentDefinition.Parameters Dim exists As Boolean exists = False 'Find out if parameter exists, if not it will create this parameter in the table, if you want another name then change Sweeplength to something else For Each oparam In oparams If oparam.Name = "SWEEP_LENGTH" Then exists = True Next oparam 'Change the value if the parameter exists otherwise add the parameter If exists Then oparams.Item("SWEEP_LENGTH").Value = TotalLength Else oparams.UserParameters.AddByValue("SWEEP_LENGTH", TotalLength, 11266) End If InventorVb.DocumentUpdate()
Thank you for the support,
Reinaldo Roth
