Send a CTRL+TAB keystroke to iProperties dialog with iLogic
Message 1 of 23
Ok I have an iLogic rule that opens the iProperties dialog for the file type that is active.  That much I got.  Now I need to send a CTRL + TAB keystroke after it is opened so that the 'Summary' tab is active when the iProperties dialog is shown.
here is the code I got:
SyntaxEditor Code Snippet
Imports System.Windows.Forms
Sub Main()
    Dim oCommandMgr As CommandManager
        oCommandMgr = ThisApplication.CommandManager
    Dim oControlDef As ControlDefinition
     oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingiPropertiesCmd")
    Call oControlDef.Execute '2(False)
    SendKeys.SendWait("^{TAB}")  '← I'm guessing that the '^' carot is supposed to be the 'CTRL key'  but all this does is just a normal 'TAB' which sets the 'Help' active
    ThisApplication.UserInterfaceManager.DoEvents()
End Sub
Please do not reply with HOW to get the dialog to open I know how to do that I just want the Summary TAB to be the active tab when it does.
Replies (22)
Message 2 of 23
MjDeck
It seems like it's not sending the CTRL successfully. But you can use the right arrow instead:
Sub Main()
    Call oControlDef.Execute2(False)
    SendKeys.SendWait("{RIGHT}")
End Sub
Mike Deck
Software Developer
Autodesk, Inc.
Message 3 of 23
Curtis_Waguespack
This is useful stuff , thanks!
Adding to what @MjDeck provided here is rule I just created that open the iProperty dialog to the Custom tab for any parts, assemblies and drawings.
I hope this helps.
Curtis
Sub Main()
	doc = ThisDoc.ModelDocument
	'check file type
	If doc.DocumentType = kPartDocumentObject Then
		oCmd = "PartiPropertiesCmd"
	Else If doc.DocumentType = kAssemblyDocumentObject Then
		oCmd = "AssemblyiPropertiesCmd"
	Else If doc.DocumentType = kDrawingDocumentObject Then
		oCmd = "DrawingiPropertiesCmd"
    oControlDef = oCommandMgr.ControlDefinitions.Item(oCmd)
	'opens to Custom tab ( send "right arrow" key 4 times)
    SendKeys.Sendwait("{RIGHT 4}")
End Sub
Message 4 of 23
Great, but only when using in a drwing gives me an error:
Error in rule: ShowCustomiProperty, in document: Drawing1.dwg
De objectvariabele of With block-variabele is niet ingesteld.
Message 5 of 23
Thank you gentlemen for the solutions they work great.
@Anonymous   I get the same thing with a drawing file but the part and assembly work perfectly.  I need them to go to the comment section most of the time so here is the code to open to the Comments:
 Here's the fix:
Sub Main()
	doc = ThisDoc.Document
	'check file type
	'opens to Summary tab, Comments Box ( send "right arrow" key 4 times and "TAB" key 9 times)
    SendKeys.Sendwait("{RIGHT}{TAB 9}")
End Sub
Message 6 of 23
RoyWickrama_RWEI
I was trying to use your code to get around to the OK button activated after entering data for comments.
I appreciate if you would help me to get the OK button at the 3rd time the Enter button is pressed (it is similar to pressing TAB key after pressing the enter button (say for two times)
Sub oCheckIn()
'	ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(False)
	oControlDef = oCommandMgr.ControlDefinitions.Item("VaultCheckinTop")		'.Execute2(False)
End Sub
Message 7 of 23
MjDeck
@RoyWickrama_RWEI , the attached text file has a modified version of your rule. It gets the TAB key to work as expected by using the SetForegroundWindow function. I tested this with a simple check-in workflow. But there's no guarantee. I don't think it will work in all situations.
Mike Deck
Software Developer
Autodesk, Inc.
Message 8 of 23
RoyWickrama_RWEI
Thanks MjDeck.
It works fine if we don't type in any comments.
It also helped me learning to use {SHIFT} and {Enter} and the similar. I wanted this in several times.
In practice, we need to type in data for comments at Checkin and therefore I need to do as follows:
'After typing data in (or without any data types in), when the ENTER button is pressed, the cursor moves To the beginning of 2nd line awaiting for data typed in the 2nd line. But, instead of cursor shifting to the 2nd row (keeping the Checking dialog box is open yet), hitting {ENTER} button should prompt the user input to do so (using vbYes) or to mimic {TAB} and then {ENTER}} functions so that, checkin will be done.
	L_Comments:
	'Code for entering Comments (1st row only)
	oYesNo = MessageBox.Show("Do you want to type comments in next row?", "TYPE COMMENTS IN NEXT ROW", MessageBoxButtons.YesNo)
	If oYesNo = vbYes Then GoTo L_Comments :
 Note: Usually it is only a one row of comments. But, option is available for typing comments in as many rows as required.
Advantage is that after typing comments in, pressing (2X) {ENTER} with the same finger will finish every thing up.
At work, I some times process 20, 30 or more documents in a day. This rule will make it easier the work.
Would you try helping me to get around this.
I am on the continuous learning in iLogic and moving to APT. But, being a non-programmer, a lot more to go, I believe. I love it anyway: I can't do without customization.
Autodesk Inventor/Vault 2019 - Professional (@ home)
Autodesk Inventor/Vault 2018 - Professional (@ work)
Message 9 of 23
MjDeck
I don't think there's a way to drive the dialog with a rule while also interacting with the dialog to type in comments. You could do that with an external EXE that talks to Inventor. But an iLogic rule is more limited.
Here's a version of the rule that will let you enter comment lines. Instead of entering them in the dialog, you type them into standard input boxes. Enter a blank line to proceed. Then the rule feeds the lines to the dialog.
There's a limitation: if you have entered comments when you checked the file out, and you enter new comments here on check-in, the check-out comments will be lost. Unless you use an external EXE that could see the existing checkin comments, I don't think there's a way around that.
Mike Deck
Software Developer
Autodesk, Inc.
Message 10 of 23
RoyWickrama_RWEI
Thanks for taking time to help me.
The rule is not bad, because it leaves the option to type in comments. But, at the end, the document remains checked out. I can't ask you to spend more time on this. But, if you do, I shall be most grateful to you. Anyway, take your time and take it easy (no rush at all).
Message 11 of 23
MjDeck
I tested it with a part. It worked for me as long as the part does not require saving. Please try saving the part first, then run the rule.
Mike Deck
Software Developer
Autodesk, Inc.
Message 12 of 23
RoyWickrama_RWEI
Oh, yes. You are right. Thank you Sir.
Roy Wickrama
Message 13 of 23
RoyWickrama_RWEI
It is a solution. Sorry, I have no option to accept as a solution.
Message 14 of 23
RoyWickrama_RWEI
Thanks. It is working.
I changed a little bit so that the document is saved (in case not saved already). Also, activated the vault pane to take a look at Checked-In status.
option explicit on
Imports System.Runtime.InteropServices
Sub Main
	ThisDoc.Save
	CheckIn()
End Sub
<DllImport("user32.dll", SetLastError:=True, CharSet:=CharSet.Auto)> _
Private Shared Function SetForegroundWindow(hWnd As IntPtr) As Integer
End Function
Sub CheckIn()
	Dim commentLines As New List(Of String)
	Dim line As String = String.Empty
	For i As Integer = 1 To 10
		Dim prompt = String.Format("Enter comment line {0}", i)
		line = InputBox(prompt, "Enter an empty line to proceed with checkin")
		If String.IsNullOrEmpty(line) Then Exit For
		commentLines.Add(line)
	Next
	SetForegroundWindow(ThisApplication.MainFrameHWND) ' Call this so that the main Inventor window will get the TAB key.
	Dim oCommandMgr As CommandManager = ThisApplication.CommandManager
	Dim oControlDef = oCommandMgr.ControlDefinitions.Item("VaultCheckinTop")
	Dim allForSend As String = String.Empty
	For i As Integer = 0 To commentLines.Count - 1
		allForSend = allForSend + commentLines(i) + If(i < commentLines.Count - 1, "{ENTER}", "" )
	Next
	allForSend = allForSend + "{TAB}{ENTER}" ' Tab to the OK key and hit Enter to click it.
    SendKeys.SendWait(allForSend)
	oSub_VaultPane()
End Sub
Sub oSub_VaultPane()
Dim oCurrentPaneName As String
oCurrentPaneName = ThisApplication.ActiveDocument.BrowserPanes.ActivePane.Name
If oCurrentPaneName = "Model" Then
	ThisApplication.ActiveDocument.BrowserPanes.Item("Vault").Activate
Else
	'if anything else toggle to Model
'	ThisApplication.ActiveDocument.BrowserPanes.Item("Model").Activate
End Sub
Message 15 of 23
RoyWickrama_RWEI
Hi MjDeck;
I am using the rule you provided.
I accidentally hit enter button without data in for the 1st line of comments. I rather like the used is forced to input data for the 1st line.
Could you further revised the code so that checkin will go if data typed in for Line 1 (at least).
Thanks.
Message 16 of 23
MjDeck
You can check for at least one comment line by adding these lines of code after the "Next" line.
If commentLines.Count = 0 Then
	MessageBox.Show("Please enter at least one comment line", "File not checked in", MessageBoxButtons.OK, MessageBoxIcon.Warning)
	Return
Mike Deck
Software Developer
Autodesk, Inc.
Message 17 of 23
RoyWickrama_RWEI
Thanks a lot.
That. fine. COOL.
Message 18 of 23
Mike_Y2
I have tweaked this to go to select the third custom Iproperty, then select the "Value" field. Does anyone know how this could be changed so that...
In an assembly you select a part, then it would open the Iproperties for the selected part (selecting the third custom Iproperty, then select the "Value" field)
Sub Main()
	'check file type
	'Opens Iproperties and sends "right arrow" key 4 times and "TAB" key 2 times)
	SendKeys.SendWait("{Right 4}{TAB 2}{A}{DOWN 3}{TAB 2}")
End Sub
Message 19 of 23
Curtis_Waguespack
Hi @Mike_Y2
You can give this example a try.
I hope this helps.
Curtis
Sub Main()
oMsg = "Select a component (press ESC to exit select)"
Dim oOcc As ComponentOccurrence
oOcc = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kAssemblyOccurrenceFilter, oMsg)
oOcc.Edit
Dim oDoc As Document
oDoc = oOcc.Definition.Document
'check file type
If oDoc.DocumentType = kPartDocumentObject Then
Else If oDoc.DocumentType = kAssemblyDocumentObject Then
Else If oDoc.DocumentType = kDrawingDocumentObject Then
Try
oOcc.ExitEdit(ExitTypeEnum.kExitToPrevious)
Catch
End Try
End Sub
Message 20 of 23
Mike_Y2
@Curtis_Waguespack Thankyou!!!!
I have tweaked it to add a loop. You can therefore quickly edit a custom Iproperty for several parts in an assembly...
'https://forums.autodesk.com/t5/inventor-customization/send-a-ctrl-tab-keystroke-to-iproperties-dialo...
Sub Main()
'Get user to close any open part files
'If part files are left open and the user selects that part file in the assemble THEN...
'Inventor will swap To the part file Then open the iProperties dialog box
oUserQ1 = MessageBox.Show("Close any open part files before using this rule" _
& vbCrLf & vbCrLf & vbCrLf & " Do you want to continue?", "Realm Toolkit", _
'Exit if the user selects No
If oUserQ1 = vbNo Then
Exit Sub
'Loop until user presses ESC
Do
'Select the part
oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a component (Press ESC to exit select)")
'Exit if the user presses ESC
If oOcc Is Nothing
GoTo ExitSelectLoop
'Edit the selected part
oOcc.Edit
'Check file type
SendKeys.SendWait("{Right 4}{TAB 2}{A}{DOWN}{TAB 2}")
'Exit editting the selected part
Try
Catch
End Try
Loop
ExitSelectLoop:
End Sub
