Send a CTRL+TAB keystroke to iProperties dialog with iLogic
Message 1 of 23
Ok I have an iLogic rule that opens the iProperties dialog for the file type that is active.  That much I got.  Now I need to send a CTRL + TAB keystroke after it is opened so that the 'Summary' tab is active when the iProperties dialog is shown.
here is the code I got:
SyntaxEditor Code Snippet
Imports System.Windows.Forms
Sub Main()
    Dim oCommandMgr As CommandManager
        oCommandMgr = ThisApplication.CommandManager
    Dim oControlDef As ControlDefinition
     oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingiPropertiesCmd")
    Call oControlDef.Execute '2(False)
    SendKeys.SendWait("^{TAB}")  '← I'm guessing that the '^' carot is supposed to be the 'CTRL key'  but all this does is just a normal 'TAB' which sets the 'Help' active
    ThisApplication.UserInterfaceManager.DoEvents()
End Sub
Please do not reply with HOW to get the dialog to open I know how to do that I just want the Summary TAB to be the active tab when it does.
Replies (22)
Message 21 of 23
Curtis_Waguespack
 Hi @Mike_Y2
Nice..... here's a version that deals with other open files in step, by adding a line to close the active edit document to the Try/Catch at the end.
I hope this helps.
Curtis
imports System.Windows.Forms
'https://forums.autodesk.com/t5/inventor-customization/send-a-ctrl-tab-keystroke-to-iproperties-dialo...
Sub Main()
'Loop until user presses ESC
Do
	'Select the part
	Dim oOcc As ComponentOccurrence
	oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a component (Press ESC to exit select)")
	'Exit if the user presses ESC
	If oOcc Is Nothing
		GoTo ExitSelectLoop
	'Edit the selected part
	oOcc.Edit
	Dim oDoc As Document
	oDoc = oOcc.Definition.Document
	'Check file type
	If oDoc.DocumentType = kPartDocumentObject Then
		oCmd = "PartiPropertiesCmd"
	Else If oDoc.DocumentType = kAssemblyDocumentObject Then
	oCmd = "AssemblyiPropertiesCmd"
	Else If oDoc.DocumentType = kDrawingDocumentObject Then
	oCmd = "DrawingiPropertiesCmd"
	oControlDef = oCommandMgr.ControlDefinitions.Item(oCmd)
	Call oControlDef.Execute2(False)
	'Opens Iproperties and sends "right arrow" key 4 times and "TAB" key 2 times)
	SendKeys.SendWait("{Right 4}{TAB 2}{A}{DOWN}{TAB 2}")
	'Exit editting the selected part
	Try
		oOcc.ExitEdit(ExitTypeEnum.kExitToPrevious)
	Catch
		ThisApplication.ActiveEditDocument.close
	End Try
Loop
ExitSelectLoop :
End Sub
Message 22 of 23
Mike_Y2
@Curtis_Waguespack  I used this but it appears to save the part document (that is being closed) without prompting the user to confirm if they want to save the document or not. I have therefore tweaked it to just open the assembly again...
Sub Main()
	'Record the assembly name
	oAssembly = ThisApplication.ActiveDocument.fulldocumentname
	Do
		'Select the part
		If oOcc Is Nothing
			GoTo ExitSelectLoop
		oOcc.Edit
		'Check file type
		'Exit editting the selected part / return to the assembly
		Try
		Catch
			'ThisApplication.ActiveEditDocument.close
			ThisApplication.Documents.Open(oAssembly)
		End Try
	Loop
	ExitSelectLoop :
End Sub
Message 23 of 23
Curtis_Waguespack
Hi @Mike_Y2
There is an option to "skip save" for the close method, that would work here also.
I hope this helps.
Curtis
		Try
		Catch
			ThisApplication.ActiveEditDocument.close(true)
		End Try
Document.Close( [SkipSave] As Boolean )
Name Type Description
SkipSave Boolean Optional input Boolean that specifies whether to skip the save. If SkipSave is set to True, it indicates that the changes to the document should not be saved and that the document should be closed silently. If SkipSave is set to False, it indicates that the normal save process should be followed (including prompting a dialog to the user). In addition, if Application.SilentOperation is set to True, the default choice on the dialog should be accepted. The Close method will fail if the combination of SkipSave = False and SilentOperation = True is used for a previously unsaved document.
This is an optional argument whose default value is False.
