How To Add a UserControl Or Userform to a DockableWindow in Inventor?
bradeneuropeArthur
Mentor Mentor
Message 1 of 28
bradeneuropeArthur
I have this sample but i would like to add labels; textboxes; etc to the Dockablewindow.
Dim oUserInterfaceMgr As UserInterfaceManager
        oUserInterfaceMgr = ThisApplication.UserInterfaceManager
        ' Create a new dockable window
        Dim oWindow As DockableWindow
        oWindow = oUserInterfaceMgr.DockableWindows.Add("SampleClientId", "TestWindowInternalName", "Test Window")
        ' Get the hwnd of the dialog to be added as a child
        ' CHANGE THIS VALUE!
        Dim hwnd As Long
        hwnd = 4851096
        ' Add the dialog as a child to the dockable window
        oWindow.AddChild(hwnd) Her I would like to add a UserControl or Userfrom!!!!!
        ' Don't allow docking to top and bottom
        oWindow.DisabledDockingStates = DockingStateEnum.kDockTop And DockingStateEnum.kDockBottom
        ' Make the window visible
        oWindow.Visible = True
Does anyone have a sample for this?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Accepted solutions (3)
Replies (27)
Message 2 of 28
marcin_otręba
Try this:
        Private Sub AddToUserInterface()
            Dim addInCLS As GuidAttribute
            addInCLS = CType(System.Attribute.GetCustomAttribute(GetType(StandardAddInServer), GetType(GuidAttribute)), GuidAttribute)
            addInCLSIDString = "{" & addInCLS.Value & "}"
            Dim uiMgr As UserInterfaceManager = g_inventorApplication.UserInterfaceManager
            Dim myDockableWindow As DockableWindow = uiMgr.DockableWindows.Add(addInCLSIDString, "MyWindow", "My Add-in Dock")
            myDockableWindow.Visible = True
            myDockableWindow.DockingState = DockingStateEnum.kDockRight
            myDockableWindow.AddChild(CreateChildDialog())
        End Sub
        Public Function CreateChildDialog() As Long
            If Not oForm Is Nothing Then
                oForm.Dispose()
                oForm = Nothing
            oForm = New projektcntr
            oForm.Show()
            Return oForm.Handle.ToInt64()
        End Function
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 28
bradeneuropeArthur
Thanks for the code.
Do you know if it is possible to add a Usercontrol (VB.net) to the DockableWindow too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 28
marcin_otręba
i do not remember but you can add userform and turn off frames, maximalize, minimalize buttons  and all and it will look like control.  Mine look like this
Message 5 of 28
bradeneuropeArthur
Think that the UserControls are not modeless (showdialog), that is why it is not funcioning!
Thanks for your help!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 28
bradeneuropeArthur
Any idea how to update the form with properties and values form the active document?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 28
marcin_otręba
i do it OnActivateDocument.
then just type oform.textbox1.text=....
Message 8 of 28
bradeneuropeArthur
when i do that i receive en error.
could you send an example for me?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 28
marcin_otręba
        Private Sub m_AppEvents_OnActivateDocument(ByVal DocumentObject As Inventor._Document, _
                                                    ByVal BeforeOrAfter As Inventor.EventTimingEnum, _
                                                     ByVal Context As Inventor.NameValueMap, _
                                                    ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_AppEvents.OnActivateDocument
            If BeforeOrAfter <> EventTimingEnum.kAfter Then
                Exit Sub
            Dim odoc As Inventor.Document
            odoc = g_inventorApplication.ActiveEditDocument
            Dim eDocumentType As DocumentTypeEnum = odoc.DocumentType
            Dim chb As CheckBox
            Dim sDocumentType As String = "Unknown"
            Select Case eDocumentType
                Case DocumentTypeEnum.kAssemblyDocumentObject
                    For Each a As Control In oform.GroupBox1.Controls
                        If TypeOf a Is Windows.Forms.TextBox Then
                            a.Text = Nothing
                    Next
                    Dim odef As AssemblyComponentDefinition = odoc.componentdefinition
                    Dim occ As ComponentOccurrence
                    For Each occ In odef.Occurrences
                        If TypeOf occ.Definition Is AssemblyComponentDefinition Then
                            '              oForm.ComboBox1.Items.Add(occ.Name)
                    Next
                    oform.TextBox1.Text = odef.Parameters.UserParameters.Item("height").Value * 10
                    oform.TextBox2.Text = odef.Parameters.UserParameters.Item("width").Value * 10
                    oform.TextBox3.Text = odef.Parameters.UserParameters.Item("depth").Value * 10
                    oform.TextBox4.Text = odef.Parameters.UserParameters.Item("front_bolt_qty").Value
                    oform.TextBox5.Text = odef.Parameters.UserParameters.Item("front_bolt_distance").Value * 10
                    oform.TextBox6.Text = odef.Parameters.UserParameters.Item("top_bottom_bolt_qty").Value
                    oform.TextBox7.Text = odef.Parameters.UserParameters.Item("top_bottom_bolt_distance").Value * 10
                    oform.GroupBox1.Text = odoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
                    For idx = 1 To oform.GroupBox1.Controls.Count
                        chb = oform.GroupBox1.Controls.Item(idx)
                        If odoc.PropertySets.Item("Inventor User Defined Properties").Item(oform.GroupBox1.Controls.Item(idx).Text).Value = "1" Then
                            chb.Checked = 1
                        Else
                            chb.Checked = 0
                    Next
                    '  sDocumentType = "Assembly Document"
                    '      oForm.ComboBox1.Items.Clear()
                    ' oForm.TextBox1.Text = ""
              Case DocumentTypeEnum.kPartDocumentObject
                    sDocumentType = "Part Document"
                    Dim opdef As PartComponentDefinition = odoc.componentdefinition
                            a.Text = Nothing
                    Next
                            chb.Checked = 1
                        Else
                            chb.Checked = 0
                    Next
                    oform.TextBox1.Text = opdef.Parameters.UserParameters.Item("height").Value * 10
                    oform.TextBox2.Text = opdef.Parameters.UserParameters.Item("width").Value * 10
                    oform.TextBox3.Text = opdef.Parameters.UserParameters.Item("depth").Value * 10
                    oform.TextBox4.Text = opdef.Parameters.UserParameters.Item("front_bolt_qty").Value
                    oform.TextBox5.Text = opdef.Parameters.UserParameters.Item("front_bolt_distance").Value * 10
                    oform.TextBox6.Text = opdef.Parameters.UserParameters.Item("top_bottom_bolt_qty").Value
                    oform.TextBox7.Text = opdef.Parameters.UserParameters.Item("top_bottom_bolt_distance").Value * 10
            End Select
     End Sub
Message 10 of 28
bradeneuropeArthur
How to prevent the userform from scaling weird.
I am missing the buttons and the other controls on it because is scaled wierd...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 28
HideoYamada
You can use UserControl also.
Following app which I made uses UserControl instead of Form. (See the video on the page)
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=2638190254159513577&appLang=en&os=Win64
Keep mind that the dockable window with user control may have trouble about control keys such as 'Enter' or 'Tab'.
Dockable window with user control is not catching enter key press?
I wrote the difference between Form and UserControl in the above thread.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 12 of 28
bradeneuropeArthur
Hi @HideoYamada @marcin_otręba ,
Any idea how to be sure that the userform or the usercontrol scales to the Dockable window?
At the moment the Userform scales weird (to large) and does not fit the Dockable Window size.
I have set the userform to a fix height and now the buttons are visible, but is this the correct way of preventing the UserForm or UserControl from scaling?
What are the correct dimensions (Weight and Width) for the UserFrom or UserControl?
Thank you for the support on this,
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 28
HideoYamada
Are you saying that the content of your dockable window isn't resized when the dockable window is resized?
Try change the border style of userform or usercontrol to none.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 14 of 28
marcin_otręba
you can use dockablewindow.width and height to set up your form width and height onload, also you can use dockablewindow.SetMinimumSize functionality, i assume that in your form you have correct anchors and settings for its content.
Message 15 of 28
bradeneuropeArthur
The UserForm or UserControl becomes to large in the Dockable window and the bottons are out of the field, you understand?
I need to take a look at the Anchors!!! @marcin_otręba
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 28
bradeneuropeArthur
At what moment do you add the oForm to the DockableWindow?
  1. on ActivateDocument?
  2. on initialize the add in?
Can't get this to work since I cannot update the created form on activate document!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 28
marcin_otręba
Yes i understand! also it would be nice if you could attach some scren showing your situation.
I always try to design my forms in size wchich they will appear. Also content should be achored to side in wchich dockable window will be docked.
I have it is couple of my addins and it is added :
1. on custom button click
2. as i showed in my first answer - on addtouserinterface:
        End Sub
3.on assembly doc activate.
Can't get this to work since I cannot update the created form on activate document! - what do you mean?
if you dont want to shear on forum you can write me message or something, also if you could describe what you want to acomplish, i think i have alot of experience with dockable windows and i propably did it already. I use them almost on all possible document events.
Message 18 of 28
bradeneuropeArthur
Thank you @marcin_otręba
I got it working.
  • Step one is to declare the Userform as a Public new form to the StandardAddInServer:
Public Class StandardAddInServer
        Implements Inventor.ApplicationAddInServer
        ' Inventor application object.
        Private m_inventorApplication As Inventor.Application
        Private m_ClientID As String
        Public m_Form As StartFormulier
  •  Then on the document event I am the first time adding the userform to the DockableWindow:
                If BeforeOrAfter = EventTimingEnum.kAfter Then
                    m_Form.Show()
                    Dim docw As DockableWindow
                    Try
                        docw = m_inventorApplication.UserInterfaceManager.DockableWindows.Add("1234xyz", "1234yyz", "My Dockabel Window")
                        docw.AddChild(m_Form.Handle.ToInt64)
                    Catch ex As Exception
                    End Try
    m_Form.Text = DocumentObject.DisplayName
    m_form.....Etc Etc
    Now I am able to access the m_form as I need.
    The form is used to display and edit the Company mandatory I-properties.
Any better suggestions from your side to accomplish this?
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 28
marcin_otręba
I did something like that, i used onactivatedocument(here i used ActiveEditDocument) and onpreselectevents - here i run code if selected entity was comp occurrence and count was =1
Message 20 of 28
bradeneuropeArthur
A "fine tuning" question.
How to prevent the shown UserForm from being shortly visible in the inventor screen when the DockableWindow is created.
The Userform is very short visible before it is added to the Dockable window.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
