Change a number in a range using I-logic
I have a question. I made in my past several I-logic rule, only now im running stuck.
I want to round up my custom property (weight="gewicht").
Only when i get the mass the custom property keeps on 0. Why?
I made the following rule:
Dim propertyName As String = "Gewicht"
If (mass <= 30) Then
	iProperties.Value("Custom", "Gewicht") = Ceil(mass / 1) * 1 & " Kg"
ElseIf (mass > 30) And (mass <= 100)  Then
	iProperties.Value("Custom", "Gewicht") = Ceil(mass / 5) * 5 & " Kg"
ElseIf (mass > 100) And (mass <= 1000)  Then
	iProperties.Value("Custom", "Gewicht") = Ceil(mass / 10) * 10 & " Kg"
ElseIf (mass > 1000) Then
	iProperties.Value("Custom", "Gewicht") = Ceil(mass/50)*50 & " Kg"
 Can someone help me out, thx.
Sergio.D.Suárez
Hi, Try the following rule, I have not used the ilogic shortcut to access the property of mass, because this access uses the units that you assign to the document, then use the access that uses the units in kg regardless of the units used in Document properties
I placed a message box to check that the value has the unit I need, then I have grayed it out as a comment.
Dim oDoc As Document = ThisDoc.Document
Dim oCD As ComponentDefinition = oDoc.componentdefinition
Dim oMass as Double = oCD.MassProperties.mass' units in kg
'MessageBox.Show(oMass)
If (oMass <= 30) Then ' oMass <= 30 kg
	iProperties.Value("Custom", "Gewicht") = Ceil(oMass / 1) * 1 & " Kg"
ElseIf (oMass > 30) And (oMass <= 100)  Then
	iProperties.Value("Custom", "Gewicht") = Ceil(oMass / 5) * 5 & " Kg"
ElseIf (oMass > 100) And (oMass <= 1000)  Then
	iProperties.Value("Custom", "Gewicht") = Ceil(oMass / 10) * 10 & " Kg"
ElseIf (oMass > 1000) Then
	iProperties.Value("Custom", "Gewicht") = Ceil(oMass/50)*50 & " Kg"
I hope this helps solve your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you very much!
