iLogic: Create constraint with reference to Parameter (rather than value)
Components.Add("MyNewComponent", MyFile.ipt)
Constraints.AddFlush("Flush:1", "MyNewComponent", "XY Plane", "", "XY Plane", Distance
 Distance is an Inventor Parameter. This code works, but when I edit the constraint, the Offset is the value of "Distance" (at the time of running the rule). I would like the offset to be a reference to "Distance" instead (so that the offset updates automatically when the parameter is changed).
Replacing "Distance" with Parameter("Distance") has no effect.
marcin_otręba
Try this:
Constraints.AddFlush("Flush:1", "MyNewComponent", "XY Plane", "", "XY Plane", "Distance")
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Oh dear. This works fine!
I was sure I tested that yesterday, and it complained about "Distance" not being a double. Must have referenced an iLogic parameter.
Thank you!
