How to add a friction diameter from input parameter d0 ?
deffysalfauzi
deffysalfauzi
Good afternoon,
Help me, this is a code for the description:
=<Material>, Ø<Diameter> x <SweepLength> mm
How to add a friction diameter?
bradeneuropeArthur
you mean I think a fractional diameter?!
Dim p As PartDocument = ThisDoc.Document
iProperties.Value("Project", "Description") = p.ComponentDefinition.Parameters.UserParameters.Item("Diameter").Expression
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
deffysalfauzi
yes, fractional diameter. Sorry typo. or as I input it. i.e : entry = 1 1/8" then result = 1 1/8, or entry = 34 mm then result 34. Can it be coded?
bradeneuropeArthur
With the above code you can get the exact expression of for example "Diameter" Parameter....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
