How do I make the parameter values of the same frame assemblies in the assembly independent of each other?
hayattangercekler2
hayattangercekler2
I have an assembly that is a profile part made of a frame in an assembly (iam). Afterwards, I copy 3 pieces of this assembly (iam) file into another iam file by changing their lengths. When I come to the final assembly, all 3 have the same size. Do the parameter names happen because their components are the same, or is there a different reason?
I am changing the value of the length parameter and all 3 are changing.
CattabianiI
That is because they're different occurrences of the same document. Changing parameter is a document level thing. So you cannot achieve what you want.
hayattangercekler2
Yes, I tried many methods until I saw that it was like this. I was able to solve this problem as follows.
I made copies in different folders for as many copies as I wanted. So I created their own folder for each track. This is how I got what I wanted.
