Export to dxf with custom iProperties in new file name
kresh.bell
kresh.bell
is it possible for someone to help me? I need an iLogic that would:
- works in an assembly environment
- all selected parts, export face to dxf (v 2010), if sheet metal then flat pattern, without bending line
- name as follows (file name)_(custom iPropertie MATERIAL_SIFRA)_(custom iPropertie DEB)mm_(number of pieces in assembly)x
JelteDeJong
This is a difficult question.
First of all, there is no way to select multiple documents that you want to export. Here I solved this by opening each file. if you don't select a face. (press escape) then it will skip the part.
Maybe a bigger problem there is no API for exporting faces. There is a workaround. You can execute commands as you clicked on them. this is unstable but might work for you. This is what the rule below does. (I also left the other 2 ways of exporting documents in the code for educational purposes)
Sub Main()
	Dim doc As AssemblyDocument = ThisDoc.Document
	Dim bom As BOM = doc.ComponentDefinition.BOM
	bom.PartsOnlyViewEnabled = True
	Dim bomView As BOMView = bom.BOMViews.Item("Parts Only")
	For Each row As BOMRow In bomView.BOMRows
		Try
			Dim refDoc As Document = row.ComponentOccurrences.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
			If (refDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then
				Continue For
			Dim openDoc = ThisApplication.Documents.Open(refDoc.FullFileName)
			Dim newFileName As String = createFileName(openDoc, row.TotalQuantity)
			If (openDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
				Dim defSheetMetal As SheetMetalComponentDefinition = openDoc.ComponentDefinition
				If defSheetMetal.HasFlatPattern = False Then
					defSheetMetal.Unfold()
				Else
					defSheetMetal.FlatPattern.Edit()
				exportFace(openDoc, newFileName)
				defSheetMetal.FlatPattern.ExitEdit()
			Else
			openDoc.Close()
		Catch ex As Exception
			Try
				MsgBox("Problem with file: " &
							row.ComponentOccurrences.Item(1)._DisplayName &
						"Message: " & ex.Message)
			Catch
			End Try
		End Try
	Next
End Sub
Function createFileName(doc As PartDocument, quantity As String) As String
	Dim dirName As String = IO.Path.GetDirectoryName(doc.FullFileName)
	Dim fileNameWithoutExtension As String = IO.Path.GetFileNameWithoutExtension(doc.FullFileName)
	Dim propSet As PropertySet = doc.PropertySets.Item("Inventor User Defined Properties")
	Dim MATERIAL_SIFRA = GetPropValue(propSet, "MATERIAL_SIFRA")
	Dim DEB = GetPropValue(propSet, "DEB")
	Return String.Format("{0}\{1}_{2}_{3}mm_{4}x.dxf",
	dirName, fileNameWithoutExtension, MATERIAL_SIFRA, DEB, quantity)
End Function
Function GetPropValue(propSet As PropertySet, name As String) As String
	Try
		Return propSet.Item(name).Value
		Return "~Unknown~"
	End Try
End Function
Sub exportFace(doc As PartDocument, newFileName As String)
	Dim face As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select a face to export. Esc to skip")
	If face Is Nothing Then Return
	' Many options but does not work for faces
	'Dim def As PartComponentDefinition = doc.ComponentDefinition
	'Dim sketch = def.Sketches.Add(face, True)
	'Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2010&InvisibleLayers=BendUpLayer;BendDownLayer"
	'sOut = ""
	'sketch.DataIO.WriteDataToFile(sOut, newFileName)
	'sketch.Delete()
	' Many options but in a seperate file. Does not work with faces
	'Dim DXFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
	'Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
	'oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	'Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	'Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
	'If DXFAddIn.HasSaveCopyAsOptions(doc, oContext, oOptions) Then
	'	Dim strIniFile = "C:\temp\DxfExport.ini" 'this is a pre-configed ini file
	'	oOptions.Value("Export_Acad_IniFile") = strIniFile
	'	oDataMedium.FileName = newFileName
	'	DXFAddIn.SaveCopyAs(face, oContext, oOptions, oDataMedium)
	'End If
	' no options posible but works for faces.
	Dim oCtrlDef As ButtonDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
	doc.SelectSet.Select(Face)
	ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, newFileName)
	oCtrlDef.Execute()
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
kresh.bell
thank you very much, sorry to deelay, I was sick.
It works great, face selection is not a problem. Is it possible to somehow limit the participating parts? For example by selection.
I often have a case when I have an assembly with many parts and I only need a few dxf faces from them
kresh.bell
does anyone have an idea how to limit this excellent iLogic to selected parts?
