iLogic Delete User Parameter
salih_kapucu
Message 1 of 8
salih_kapucu
I created a new parameter with the following code based on a condition. Depending on another condition, I want to delete this parameter. Can you write code for me?
Dim oParams As Parameters
Dim oAssemblyDoc As AssemblyDocument = ThisDoc.Document
Dim oAssemblyCompDef As AssemblyComponentDefinition = oAssemblyDoc.ComponentDefinition
oParams = oAssemblyCompDef.Parameters
Dim oUserParams As UserParameters = oParams.UserParameters
Try
  p = Parameter("TotalW")
Catch
  oUserParams.AddByValue("TotalW",myvalue, UnitsTypeEnum.kMillimeterLengthUnits)
End Try
Replies (7)
Message 2 of 8
A.Acheson
Here is what you will need. Delete method of UserParameter object
Dim p as UserParameter
Try
Catch
  p = oUserParams.AddByValue("TotalW",myvalue, UnitsTypeEnum.kMillimeterLengthUnits)
End Try
If Parameter("Check").Value = "ok" Then
p.Delete
Regards
Alan
Message 3 of 8
talha_ozdemir
Hey Acheson,
Thanks for the reply.
 We tried to use the code but on line 14, the word "Check" gives error.
Could mind to describe please whats the meaning of "Check" in the code, what it does ?
  Thanks in advance.
Message 4 of 8
tyler.warner
@talha_ozdemir see this updated code.
Dim oParams As Parameters = oAssemblyCompDef.Parameters
Try 'Add a user parameter.
	oUserParams.AddByValue("MyParam", myvalue, UnitsTypeEnum.kMillimeterLengthUnits)
Catch
End Try
Try 'Use True/False parameter "MySwitchCommand" to delete specified user parameter.
	If oUserParams.Item("MySwitchCommand").Value = "True" Then
	oUserParams.Item("MyParam").Delete
Catch
End Try
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Message 5 of 8
A.Acheson
Parameter("Check").Value is a condition you might use to determine when to delete the parameter. You can replace this parameter with whatever parameter/ condition you like. Can you explain more what conditions determine the deletion of the parameter ("TotalW")?
Regards
Alan
Message 6 of 8
salih_kapucu
@A.Acheson and @tyler.warner
Actually what i want to do is to write code like below.
if type="1" then
(Rule written to create totalW)
end if
if type="2" then
(rule written to delete totalW)
end if
Message 7 of 8
A.Acheson
Try this using api content only. The ilogic function Parameter is replaced by oUserParams.Item.
If type = "1" then
   Try
      p = oUserParams.Item("TotalW")
   Catch
   End Try
ElseIf type = "2" then
   Try
      p.Delete
   Catch
   End Try
End if
Regards
Alan
Message 8 of 8
salih_kapucu
@A.Acheson , thank you very much
