How do I go through all content center levels?
Hi!
I need to go through all content center levels, how can I do this recursively?
I need to get the family name (DisplayName).
For example:
Thank you!
bradeneuropeArthur
In VBA or Vb.net?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
for VBA the following will do:
 Public Sub LoopReadContentCenterTree()
        Dim oContentCenter As ContentCenter
        Set oContentCenter = ThisApplication.ContentCenter
        Dim a As ContentTreeViewNode
        Set a = oContentCenter.TreeViewTopNode
        Call LoopGetFromTreeView(a)
    End Sub
Private Sub LoopGetFromTreeView(oContentTreeViewNode As ContentTreeViewNode)
        Dim oContentTreeViewNodeLoop As ContentTreeViewNode
        'Dim strPath As String = b.DisplayName
        strPath = oContentTreeViewNode.FullTreeViewPath
        Dim strFam As String
        strFam = oContentTreeViewNode.DisplayName
        Dim strExport As String
        strExport = oContentTreeViewNode.DisplayName
        Dim oContentFamily As ContentFamily
        For Each oContentFamily In oContentTreeViewNode.Families
Debug.Print oContentFamily.DisplayName
        Next
        For Each oContentTreeViewNodeLoop In oContentTreeViewNode.ChildNodes
          Call LoopGetFromTreeView(oContentTreeViewNodeLoop)
        Next
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
I'm sorry, I just forgot, I'm programming in C #.
I believe that the example you have shown will be useful.
thank you.
bradeneuropeArthur
I have it in VB.net
but vba can 1to 1 copied.
I assume this will be no problem for you.
I have translated it to vba because I thought that you preferred that.
if you need in in vb.net let me know...
Here you have it in VB.net:
    End Sub
        Next
        Next
 End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
