How do I get the selectset properties during command execution?
lzs013
Message 1 of 8
lzs013
My macro code is as follows:
Public Sub selectset()
MsgBox "The cout of selectset is: " & ThisApplication.ActiveDocument.selectset.Count
End Sub
First, I draw a rectangle in the sketch, then I execute the offset command, then I select 2 edges of the rectangle, and finally I run the macro mentioned above, the result is 0.
How to get the selectset property in the command execution process ? For example, get the selectset count during the execution of the offset command.
Replies (7)
Message 2 of 8
BrianEkins
I'm getting 2 back as the count.  Can you provide a Screencast of your specific workflow?  I think maybe there's something you're doing something different that's not explained in your description.
Brian Ekins
Message 3 of 8
lzs013
Message 4 of 8
BrianEkins
Ok, I understand now.  Your original description was correct but I was misled by there only being two lines selected.  The default with the offset command is for it to automatically select a loop.
Anyway, the reason that you're not seeing anything in the select set is that when a command is running it has its own private selection and you don't have access to it.  The public select set is the set of entities that have been selected using the default Select command.  The Select command is the command that's active when no other command is running.  Pressing the Escape key causes the Select command to start and forces the currently running command to abort.
I'm not sure what you're trying to accomplish but in general, it's not possible to interact with other commands while they're running.
Brian Ekins
Message 5 of 8
lzs013
Thank you for your reply. My current attempt is to replace the interactive task in the Inventor command execution with vba instead of mouse orkeyboard.
I have a successful attempt. I use vba instead of the keyboard interaction process. When using sketch commands such as line and circle, I can use the vba hotkey to quickly position the first point to the origin. code show as below.
You said that the Inventor command can't interact with other commands during the running process. So we can use VBA to control the mouse and keyboard to participate in the interaction. But how to control the interactive events during the execution of the Inventor command via VBA? For example, use VBA to control the mouse to capture a sketch point. I don't have any clues, I hope everyone can provide some advice. thank you very much!
Sub SketchOnZero()
t = Timer
While Timer < t + 0.5
DoEvents
Wend
SendKeys "{TAB}0{TAB}0{ENTER}"
End Sub
Message 6 of 8
BrianEkins
You can mimic doing user input by driving the mouse and keyboard but I think you will always be unsatisfied with the results.  The API provides the same functionality as the user-interface but in a way that makes it easier to use through a programming language.  I would suggest looking at the API documentation.  There are some overview topics but there are also quite a few small VBA samples.  The samples demonstrating working with sketches might be especially useful.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-DE98632B-3DC0-422B-A1C6-8A5A15C99E11
Brian Ekins
Message 7 of 8
dgreatice
SelectSet is not member of Thisapplication,
SelectSet is member of Document
so change become:
Dim oDoc as document
Set oDoc = Thisapplication.ActiveDocument
...oDoc.SelectSet.Count...
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 8 of 8
lzs013
THX!
