How do I change Font Size and title the Text 45°? with I logic
Darkforce_the_ilogic_guy
Advisor Advisor
I have this code ... but the font size is too small..I want it to be 50 mm, and rotatet the text box 45°
I would like to know how I can delete the skecht again as the last thing in the code.. and only the one the code have created
I
Dim oDrawDoc As DrawingDocument
  oDrawDoc = ThisApplication.ActiveDocument
    Dim oSketch As DrawingSketch
  oSketch = oDrawDoc.ActiveSheet.Sketches.Add
 oSketch.Edit
 Dim oTG As TransientGeometry
     oTG = ThisApplication.TransientGeometry
 Dim sText As String
    sText = "Drawing Notes"
    Dim oTextBox As TextBox
 oTextBox08A = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(12, 12), "draft")
' Exit the sketch from the edit environment.
    oSketch.ExitEdit
bradeneuropeArthur
otextbox08A.Style.FontSize =10
Dim r As Double = Math.PI/2
otextbox08A.Style.Rotation = r
45 degrees not possible, only 0 90 180 360 possible!!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
your code seens to change all a lot more font size then just the textbox that it my code create .. do you know how to make it only change the single textbox ?
it changes only the created texbox "otextbox08A"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
