Hold Decimals in String
SteveK88
SteveK88
I am passing WorkPoint locations to a text file.
When the values get passed across I get whole numbers and decimals.  I'd like to keep all with 2 place decimals.
Simplified,
roundedClosest = CStr(Round(5, 2))
Results in a text value of 5
Preference is to be 5.00
Any ideas?
bradeneuropeArthur
in:
  • Ilogic?
  • VBA?
  • VB.net?
  • or else?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
With VBA:
Public Sub Stringdec()
Dim a As Variant
a = 5.1233
Dim b As Variant
b = VBA.Round(a, 0)
'MsgBox b & ".00"
Dim e As Variant
e = b & ".00"
MsgBox e
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
SteveK88
I'd like to stay in iLogic.
@bradeneuropeArthur wrote:
in:
  • Ilogic?
  • VBA?
  • VB.net?
  • or else?
SteveK88
Thanks, but this will change all decimals numbers to whole numbers.  I have a mix,
number from Inventor WorkPoints can be 5, or 5.123458.  Looking to get two place decimals in my string at all times.
5.00, 5.12 - preferred
Presently using iLogic rounding I get,
5, 5.12 - not preferred
I would like to stay in iLogic.
lmc.engineering
Hi @SteveK88
This should work for you.
Version:1.0 StartHTML:00000145 EndHTML:00000623 StartFragment:00000294 EndFragment:00000591 StartSelection:00000294 EndSelection:00000294SyntaxEditor Code Snippet
myParameter = Double.Parse(x1).ToString("0.00")
lmc.engineering
sorry, the x1 in brackets is your input
