From Solidworks to Inventor: user shortcuts and tips
Hello helpful people,
I'm trying to find a couple of the most useful features i used in SolidWorks and I have not been able to find Inventor equivalents yet, I'm hoping someone may be able to help.
Also, any additional recommendations for transitioning between solidworks to inventor would be appreciated.
1. When I am in an assembly, is there a way to have left click select a face/edge rather than the entire part/body?
2. Is there any way to have the command tree show you when an item is not fully constrained?
 3. Is there any way to have the command tree show you the part's description?
4. Is there any way to have the command tree automatically put all of your constraints into a folder?
4. Is there a way to see what items have been selected within a constraint? they don't seem to always highlight.
whiteskulleton
asdf
Shift + right click in the main area or click the button at the top.
No but you can goto view>Degrees of Freedom and see which parts cannot be moved.
No. You're going to have to make a macro.
They should be always highlighting. You can change the highlight color by going to Tools>Application Options>Colors and change the color scheme. I prefer high contrast. Also you can select a constraint in the tree and click "Other Half" to find the other part it is constrained to.
Hope this helps.
Also Mark this as the solution if this helps.
bradeneuropeArthur
About the Description as suffix:
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
about the "Is there any way to have the command tree automatically put all of your constraints into a folder?"
See the "relationship" folder in the Browser...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Whiteskulleton, thank you for taking the time to answer my questions. I really appreciate it.
bradeneurope that is extremely helpful! thank you
